C5 2.2L does not turn over..
fotobright
Unread post by fotobright »
Hi,
Another season another novelty issue :). I just had the rescue people out there but unable to start the car. Jump leads on but no sign of the starter engaging. After he tapped the starter and it tried a single revolution but after that nothing, just the tick. We noticed that the stop warning is engaged on the dashboard which is not normally there. Never had this problem before. Can't be 100% but the battery appears ok. The car unlocks and locks and the lights all work.
Its possibly a jammed starter/solenoid but could it also be something like the immobiliser or require a reset?
Any thought greatly received as ever.
Peugoet 308 SW HDI 1.6 Live*
Peugoet 207 SW Hdi 1.6
C5 2.2L HDi 16v estate (01)
Xsara Hdi 90 estate
Xantia 1.9TD estate, (veg oil)
Zx 1.9TD hatchback
Zx 1.9D hatchback
x 5658
Re: C5 2.2L does not turn over..
If the immobiliser is stopping it firing it does so by preventing the injectors firing but will allow the starter to run.
Low battery voltage will play havoc with C5's but when I thought my battery was toast it turned out to be a seized starter.
wurlycorner
x 271
Unread post by wurlycorner »
:| That's the best a recovery service could do with diagnosis? :roll: I'd ask for a bloody refund - diagnosing a starter not operating should not be rocket science for them!
You say they tried jump leads, was that just onto the battery, or did they try jump leads connected directly to the starter motor?
I'm not familiar with the starter on that engine, so if the terminals aren't accessible with the starter fitted, unbolt it and try it then. If it works fine then, the starter is fine and the problem is elsewhere on the circuit (which goes via the BSI, btw). If it doesn't work when off the car and directly connected, then the starter is knackered.
Iain
CX DTR T2 Safari (silver)
fotobright
Thanks for all the helpful info. i'll get the starter out somehow and test. I'm currently 20 miles from my tools and workshop, which tools do i need? flathead and philips csrewdriver, hexsocket (what size), extension and ratchet. Have homestart so all part of the service. strike on of three though..
Xsara Hdi 90 estate
Zx 1.9TD hatchback
Zx 1.9D hatchback
x 3300
Being Citroen you are more likely to need Torx bits, but I cannot remember what size (I did replace my starter motor about 6 months ago). The solenoid control wire is likely to be fitted with a ring connector (so it can go over a threaded rod). I do know my replacement motor used a spade connector. I got a reconditioned Bosch one from GSF for around £120, but I got back around £50 when I returned the old motor in the packaging.
x 6955
fotobright wrote:Thanks for all the helpful info. i'll get the starter out somehow and test. I'm currently 20 miles from my tools and workshop, which tools do i need? flathead and philips csrewdriver, hexsocket (what size), extension and ratchet. Have homestart so all part of the service. strike on of three though..
This might help - diagram is from a 2001 2.2 HDi Estate - although there are numerous makes of starter motor options fitted to the C5, there is only one diagram on fitting - so I guess the bolts are pretty much standard. The diagram gives the type and size of the nuts etc.:
fotobright
Thanks for diagram, most helpful.
An update. I got the starter out and used jump leads from the battery and connector wire to see if it was operational. Initially just the pin popped out but perhaps because of wrong connector wire it popped out and then spun. Its difficult to tell if its a sticky motor but it was only 49.99 last year off ebay so may be a bit crap.
Anyways I put the motor back in, cleaned the terminals and reconnected everything. started her up but its still not turning over. The computer is now telling me economy mode is active , which is new.
Whats next stage of checks? Earth cable, wiring loom check, diag reset, battery charge, test new starter?
Xsara Hdi 90 estate
Zx 1.9TD hatchback
Zx 1.9D hatchback
x 6955
fotobright wrote:Thanks for diagram, most helpful.
Whats next stage of checks? Wiring loom check, diag reset, battery charge, test new starter?
No problems, glad it helped. Your Economy Mode will kick in after a set period to conserve battery power. Usually when you've been running accessories like the radio etc., to prevent situations where the battery could drain and you won't have enough juice to start. It can kick in at anytime but usually within the 30 minutes default - or sooner if there hasn't been a good run equivalent to at least 30 minutes.
I would give the battery a good charge to be sure, but my gut would still say the starter if it is still clicking or won't turn over. (If you are going to remove the battery for a charge, follow the BSI reset, as you won't want any additional problems when diagnosing starting issues.
Bonham
Unread post by Bonham »
Have you checked the fuse for the starter? I tore down half my car just to end up with a broken fuse, my fuse looked alright but when I measured it it's was broken......
