C5 HDI 2L 2003 Lost Spare Key
ozzdownunder
Unread post by ozzdownunder »
Hi, I am located 'downunder' in Sydney Australia, own a Citroen C5 HDI 2L 2003 MODEL and have lost my spare ignition key. Does anyone know where to get another key made without having to spend millions on a key. I am aware that it apparently has a chip in the key's so just getting another key is not that simple. Other than replacing the barrel which seems a bit silly I thought there must be people like myself that hide their spare key's and don't remember their hiding place?
Any input on this is appreciated. tx
x 6955
Re: C5 HDI 2L 2003 Lost Spare Key
Getting the key cut is easy enough, but that won't be any good without the transponder chip - whether this is the fob type with the buttons or the non-button type. You can get a spare key ordered from the dealer and they can programme it for you at the garage if you don't have access to a Lexia kit, otherwise you can programme it yourself. At the end of the day, without a spare, if anything happens to the working key, you'll be snookered and will likely have to pay for one anyway - but with the added problem and expense of not being able to move or get into the car! You'll need to code ALL the keys at the same time with the Lexia - even the working one, otherwise the new one will work and the old one won't.
ozzdownunder
Thanks Marc, I have the original key, the fob type. I have a picture but not certain how to add this in the forum or if allowed to do so.
x 6955
ozzdownunder wrote:Thanks Marc, I have the original key, the fob type. I have a picture but not certain how to add this in the forum or if allowed to do so.
If you want to post a picture - you just need to use an image hosting programme like Photobucket - upload the image there and that will generate the code and link that you can paste back into your post.
It really doesn't matter which type of key you need - whether the fob with the buttons or the blade type - the buttoned one will obviously be more to buy as it has the electronics and buttons to deadlock and open / close windows etc. Both are coded the same way. They're not cheap to buy, but possibly cheaper than if your remaining key went kaput, leaving you stranded! :-D
x 6955
I was responding to your other post regarding the Heater Matrix, but it has been deleted :?:
ozzdownunder
Tx for the info, not certain why the Heater Matrix post has been deleted will check it out tomorrow tx.
x 1438
Unread post by xantia_v6 »
Sorry, I think that I deleted your heat post by mistake, there were several duplicate posts and I must have hit the delete key once too often. Please post it again.
ozzdownunder
Re: C5 HDI 2L 2003 Internal Heater Core
Hi, I would like to know if there is any install/removal information of the internal heating condenser, the one where the water runs trough to heat the internal of the cabin. This is for a Citroen C5 2003 HDI sedan chassis nr VF7**************[VIN obfuscated, can be read by forum staff] . Regards, JM
x 1438
Sorry, but we are not commercial parts suppliers (or commercial anything). This site is owned and operated by a group of volunteer enthusiasts. We take care not to have any commercial affiliations (real or implied).
Members may recommend suppliers, or buy and sell parts privately.
x 6955
ozzdownunder wrote:Hi, I would like to know if you stock a internal heating condenser, the one where the water runs trough to heat the internal of the cabin. It has a water inlet/outlet. If so do you have a picture and part number of this item. This is for a Citroen C5 2003 HDI sedan chassis nr VF7**************[VIN obfuscated, can be read by forum staff] . Price plus postage to Sydney Australia. Kind Regards. Hopefully you may have a diagram that you can send me showing how to remove and replace this part.
I think in your original post, you mentioned that you had managed to isolate the pipes, but wanted to know if there was a way to get to the Heater Matrix without removing the dash IIRC? If that's the case, I think you at least have to remove some part of the dash to get to the part (item 11 below):
Unfortunately, I only have the procedure to remove the dashboard. You may not need to follow all of it - but possibly the relevant bits to get to the matrix. If you want it as a PDF, send me a Proviate Message. I don't have a shortcut unfortunately.
The part for the Heater Matrix is 6448 J8 - An Australian dealer will be able to quote you a price I suspect. As Xantia V6 says, there's only so much we can do! :-D
ozzdownunder
Hi Marc, great thanks for that info, any info must be more useful than what I already have, now all I need is the get down to getting it done.
ozzdownunder
Hi to all I have managed to re-locate my swill hidden spare key, very happy indeed now to put it in a safe place where I can remember where it is located :-D Thanks to all that responded to my inquiry.
ozzdownunder
Hi All, I have just relocated the spare key, saving a small bundle and a lot of aggravation. Tx Again for all d feedback.
ozzdownunder
Hi, just coming back to the remote controlled key, any know where one can locate a new rubber buttons as mine are faded. tx
x 3300
You can buy replacement key membranes fro e-bay. Here is an example;
http://www.ebay.co.uk/itm/REPLACEMENT-B ... Swu4BVmrvo
