307 Automatic issues
PC2CV
x 7
Unread post by PC2CV »
A friend has a 307 1.6 Automatic.
It has an intermittent fault when travelling up hills it will go into what seems like a limp mode and the car will say "gearbox fault"
I have seen this after reading it on the PP2000 machine:
Would the pressure regulation mean low fluid,i tried to check the level but could not see any dipstick for the gearbox.
x 1460
Re: 307 Automatic issues
Unread post by xantia_v6 »
Which type of automatic transmission is fitted to the car? If you don't know, then get the VIN and someone can look it up.
PC2CV
x 7
According to servicebox its an AL4, the engine is a TU5JP4 1.6
x 1489
This box is well known for having trouble with the solenoid valves that cause pressure regulation faults and random gear engagement problems.
However, not sure if the lower 2 faults are related - they look possible more like faults with the underbonnet fuse box - are there any faults recorded in that ECU? They could be 'collateral damage' from the valves though I suppose!!
x 1055
Unread post by wheeler »
Almost certainly will need modified electrovalves & the software updated.
The other 2 faults will be 'phantom' faults.
x 1489
That's what I thought really, just hanging on there might be a crumb of comfort for the OP!!
