Removing rear spheres on a Xantia?
x 3298
Re: Removing rear spheres on a Xantia?
The advantage (if it works) of the hammer and chisel technique is that it also shocks the sphere, which can help break them loose.
HDI
x 7
Unread post by HDI »
I might well resort to that, I have a nice big cold chisel!
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
x 8461
HDI wrote:I might well resort to that, I have a nice big cold chisel!
I can confirm it works but you need a big punch too. use the cold chisel to raise a lip and then use a punch on the lip to do the rest else you’ll find a chisel just makes the lip bigger and bigger and wastes energy in enlarging the lip rather than getting the sphere loose...
I use a 4lb club hammer behind the punch...
HDI
x 7
Thanks for the tip, I have a punch too. Also a dead blow steel hammer that tends not to take prisoners!!
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
x 3298
Make sure to smack the chisel/punch squarely upon the head, and NOT upon the thumb!
x 8461
Hell Razor5543 wrote:Make sure to smack the chisel/punch squarely upon the head, and NOT upon the thumb!
That's a good tip James :wink:
x 3298
I have learnt this from others (as well as some language I cannot find in most normal dictionaries)! Something I try to do is not only to learn from MY mistakes, but to learn as well from the mistakes of OTHERS).
Stewart(oily)
x 35
Unread post by Stewart(oily) »
If the ram persists in trying to turn then ballast in the boot is what you need, my personal record is a family of four perched in the boot while I belaboured the stuck spheres!
x 8461
Stewart(oily) wrote:If the ram persists in trying to turn then ballast in the boot is what you need, my personal record is a family of four perched in the boot while I belaboured the stuck spheres!
:rofl2:
Makes a change from paving slabs or kerb stones!!!
