Removing rear spheres on a Xantia?
- x 3306
Re: Removing rear spheres on a Xantia?
The advantage (if it works) of the hammer and chisel technique is that it also shocks the sphere, which can help break them loose.
HDI
- x 7
I might well resort to that, I have a nice big cold chisel!
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
- x 8378
I can confirm it works but you need a big punch too. use the cold chisel to raise a lip and then use a punch on the lip to do the rest else you’ll find a chisel just makes the lip bigger and bigger and wastes energy in enlarging the lip rather than getting the sphere loose...HDI wrote:I might well resort to that, I have a nice big cold chisel!
I use a 4lb club hammer behind the punch...
HDI
- x 7
Thanks for the tip, I have a punch too. Also a dead blow steel hammer that tends not to take prisoners!!
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
- x 3306
Make sure to smack the chisel/punch squarely upon the head, and NOT upon the thumb!
- x 8378
That's a good tip JamesHell Razor5543 wrote:Make sure to smack the chisel/punch squarely upon the head, and NOT upon the thumb!
- x 3306
I have learnt this from others (as well as some language I cannot find in most normal dictionaries)! Something I try to do is not only to learn from MY mistakes, but to learn as well from the mistakes of OTHERS).CitroJim wrote:That's a good tip JamesHell Razor5543 wrote:Make sure to smack the chisel/punch squarely upon the head, and NOT upon the thumb!
Stewart(oily)
- x 35
If the ram persists in trying to turn then ballast in the boot is what you need, my personal record is a family of four perched in the boot while I belaboured the stuck spheres!
- x 8378
Stewart(oily) wrote:If the ram persists in trying to turn then ballast in the boot is what you need, my personal record is a family of four perched in the boot while I belaboured the stuck spheres!
Makes a change from paving slabs or kerb stones!!!
