Brake pedal mod
kiwifrog
Brake pedal mod
Unread post by kiwifrog »
I remember reading about a brake pedal mod for the Xantia but cant seem to find it , has anyone got any info on this subject ?
x 5688
Re: Brake pedal mod
x 8457
Re: Brake pedal mod
A highly recommended mod as it gives a nice firm pedal without the horrible sponginess of the standard one...
Nice thing is that if you don't like it then it's easily reversible...
elma
x 284
Re: Brake pedal mod
Unread post by elma »
I don't think Xantias feel right without it. Keep the spring though, some disagree.
x 1484
Re: Brake pedal mod
Unread post by xantia_v6 »
I did't like the pedal feel with the original configuration, but I also didn't like it with the spring removed. What worked for me was adding about 6mm pre-load to the spring to give a bit more initial bite. The pre-load was acheived by adding a couple of washers into the plastic case that holds the spring.
kiwifrog
Re: Brake pedal mod
Ok thanks guys, the brake pedal does feel a bit strange, will check it out this weekend.
Homer
x 16
Re: Brake pedal mod
Unread post by Homer »
The brake pedal mod was for people who had come from the BX/CX which had zero brake pedal travel. When you first switched from one of those to a Xantia the brakes felt very mushy.
If you have come from a car with a servo brake system it might be the other way round.
x 2008
Re: Brake pedal mod
Unread post by Stickyfinger »
I have to say I do not think they are mushy at all......but I have never (or want to) stamped on a chocolate button when I want to stop a car.
I see no reason to change the brakes, now show me a short shift kit and I am yours for the weekend :)
chinkostu
x 30
Re: Brake pedal mod
Unread post by chinkostu »
Al look for a short shift for a 406 given they should both run ML boxes on the larger ones! Although they're cable aren't they?
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
x 8457
Re: Brake pedal mod
Yes, cable but a 406 one should be OK... They both do use the same ML 'box...
