206 Problems
Tam
(Donor 2022)
x 10
206 Problems
Unread post by Tam »
Hi guys,
My daughter has asked me to "Look" at her 2006 206 Sport 1.4 :shock:
It was running fine until yesterday then the ABS light came on.
I took it a short run and the EML came on, went into "Limp" mode with the display showing "Pollution Fault" and " Catalytic Converter Fault"
Any ideas where to start? Could the latter 2 be caused by a faulty coil pack?
Thanks in advance
Tam
x 3295
Re: 206 Problems
The first thing you need to do is to get it onto a Planet Peugeot system. Anything you do until you run a diagnostics session will be a guess, and will just eat money.
Tam
(Donor 2022)
x 10
Re: 206 Problems
I want to get one as I also have a Picasso but tbh I have no idea how to use it, engine on/off etc Looks like I will deffo bite the bullet and get the system then pester you lovely guys on here :lol:
x 3295
Re: 206 Problems
Make sure to get a good system (there are cheap clones that may not have everything you need. Easy Diagnostics are not cheap, but they are reliable. If you mention that you are a member of the French Car Forum they may well knock off the cost of P&P.
http://www.easydiagnostics.co.uk/home/4592689143
jimmymarsbar
x 13
Re: 206 Problems
Unread post by jimmymarsbar »
Anti pollution fault could mean anything - it's a vague, general message which acts more as a hint to get the car looked at, rather than pointing to any specific issue.
That's where diagnostics comes in handy, codes and data are what we need :)
Is there any reason why you're suggesting the coil pack?
Pug_XUD_KeenAmateur
(Donor 2018)
x 228
Re: 206 Problems
Hmm, me thinks I'll print this off for my step-daughter, who in fairness is well entitled to be sick of her 'R' plate 106 diesel, having run it and a Mk1 for about 10years now
....but she does enjoy the cheapness with which it can be repaired and knows I'll be shy of repairing anything later & computerised.
Once again, a new (er) 206 has been put off while she chooses to spend her money on something else (its a Wedding this time) and I've breathed a bit of a sigh of relief.
Good luck with the Diagnostics !
Me... Luddite, yeah, guess so ! What'll I do when (if) my 405 wears out?!
Puxa
Tam
(Donor 2022)
x 10
Re: 206 Problems
jimmymarsbar wrote:Anti pollution fault could mean anything - it's a vague, general message which acts more as a hint to get the car looked at, rather than pointing to any specific issue.
Only reason was the sluggishness of the drive as that what happened with my Pic and a CP replacement fixed it. I guess it would be sluggish anyway in "Limp" mode. It was just a stab in the dark :-D
Tam
(Donor 2022)
x 10
Re: 206 Problems
Thanks for the buying tips and it is where I shall go, I read through the Lexia threads before and Marc was an excellent help as are you guys.
Tam
(Donor 2022)
x 10
Re: 206 Problems
Hell Razor5543 wrote:Make sure to get a good system (there are cheap clones that may not have everything you need. Easy Diagnostics are not cheap, but they are reliable. If you mention that you are a member of the French Car Forum they may well knock off the cost of P&P.
I see 2 options, which should I be looking at? One is 140 and the other is 108 and i'm unsure of the differences :?
Thanks again
x 3295
Re: 206 Problems
If you are planning on helping to fix PSA vans you will want the extra module, but if not, the normal £108 unit will do. If, at a later date, you find you need that module you can purchase it separately.
Tam
(Donor 2022)
x 10
Re: 206 Problems
Ok, as I need to wait till pay day for a lexia/PP I decided to have a visual at the coil pack. Without even getting that far, there is a thin hose that has to be removed which has yellow clips on it. This was broken in a few places but taped together and the tape came loose. Any ideas what this pipe is called? I will post a pic once I've taped it together again to see if it helps then buy a new one(Hopeless with uploading pics though). Unsure what it's called.
Tam
(Donor 2022)
x 10
Re: 206 Problems
x 1480
Re: 206 Problems
Tam
If you can get it down to me in Lanark I can run the diag on it.
Found that hose I think - is it under a cover connecting the rocker cover to the air filter box?If so, it's probably this one, but I'd need the last 8 digits of the VIN to confirm:
Reference Description Quantity Price - VAT Price + VAT Total + VAT Selection
00001192WZ OIL VAPOR HOSE 27.94 GBP 33.53 GBP 33.53 GBP
That would appear to be it - there are a few on e-bay, eg http://www.ebay.co.uk/itm/Genuine-Peuge ... xyOlhS1RBI
Huskyxantia
x 864
Re: 206 Problems
Unread post by Huskyxantia »
Do a head test, you'd be surprised what a leaking head can do
Different car, my xsara 1.4i had similar issues even garage was stuck then i went old school did a bubble test and hey presto head gasket was on its way , changed ,all good after that.
:-D
