So ive had a 2004 c5 facelift for 3 1/2 years from 64 to 105 thou miles. My friends picked up a xantia at a good price and 55 thou miles . I like it . I think im guna sell the c5 and keep the xant.
It drives real nice im quite excited !! Lol
Time for a change.......
jgra1
- (Donor 2021)
- x 36
Re: Time for a change.......
I like and have had both.. I don't think I could go back though.. what xantia is it your friend has?
John
John
zs&tas
- x 16
Hi, its a 96 1.8 auto, green. Not sure spec level, nothing fantastic. I like older cars, the seats are real comfy it has the older car lower side bigger window look. Its not a rocket ship but it floats well !
Theres a few issues were the previous owner has over maintained the car, and sunroof ( which I miss on modern cars ! ) isnt working.
Much more comfy than my c5.
Also I noticed whilst looking around it , it has some of the biggest rear doors ive seen on a 'normal car ' !?
Richard_C
- (Donor 2026)
- x 224
I had a 1.8 auto Xantia years ago, probably a 95 or 96. it was a really 'sweet' combination of engine and gearbox - not the fastest but good to live with. SX trim, no aircon but had all I needed. Would have kept it long term but I needed 7 seats at the time.
Richard_C
demag
- x 102
Out of interest the sunroof on my XM had a nasty habit of opening and not wanting to close! It was the switch. What a stupid concoction of springs and balls and bits of tin.
Dave
zs&tas
- x 16
Took it to work today, the car hasnt been used properly for a year. I did a 50 mile round trip, no issues, even got stuck in hot traffic as someone had managed to take the front of there car off and leave it facing the wrong way in the middle of the straight dual carriageway ??
It was all good and relaxed driving, funny this morning though in the dark, had no dash lights and couldnt find the dimmer switch. I have since been shown where it is ! Silly place imo !
zs&tas
- x 16
Still no dash lights but no biggy. Still driving well, ive used more revs to loosen it up and get things 'used'
Just put £20 in so checking fuel economy now, not sure what to expect ! It sits 1000 rpm higher at cruise than my c5.
Brake pedal dosnt have much movement or feel. Brakes work though ?
Gearbox down changes under braking but fairly noticeable, im not sure how noticeable this should be ?
demag
- x 102
What colour is the gearbox oil?
Dave
zs&tas
- x 16
Hi, actually theres a story behind that, as we checked it before and it looked felt and smelt more like motor oil. We have now changed half of it and the box improved . So will change the oil out again with fresh.
So basically its not red ! But we are pretty sure the previous owner or someone has chucked motor oil in at some point........
tim leech
- x 12
As its an earlier xantia they had the zf 4 speed like a bx and should only run on dextron 2, anything else will kill it, quickly!
If anyone tells you dextron 3 or 4 is an improvement ignore it!
Get the lot out quickly or you'll have a dead'un!
1994 XANTIA 1.8i SX 132k, From new,
1985 BX 19GT the beige wonder
zs&tas
- x 16
Thanks tim, ill look. What actually happens then ?
tim leech
- x 12
The gear box fails.
demag
- x 102
Gsf sell the correct oil. Nothing else will work in that box.
Dave
zs&tas
- x 16
zs&tas wrote:Thanks tim, ill look. What actually happens then ?
Haha ok thanks !tim leech wrote:The gear box fails.
chinkostu
- x 30
Xantia brakes are much different to C5 ones. the C5 uses a traditional brake booster and fluid, whereas the Xantia (and BX/XM/GS etc etc!!) use the hydraulic system, so the brake fluid is the LHM. as a result, there isn't a booster, more a valve that opens when you press the brake pedal and diverts pressurised fluid to the brake lines. the pedal as a result has really short travel!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
