cx won't start
jsp
x 12
Re: cx won't start
Unread post by jsp »
Well it started my ECU died without any reason.
battery was a bit weak seems ECU works only above 11.5V?
Few things I did before changing ECU.
Cleaning all the contacts blue relay and the main plugs.
All OK
Replaced the spark plugs just in case.
Checked for spark - OK .
Cleaned my injectors - OK
Checked fuel pressure - OK because, the fuel pump and filter is replaced two years ago.
Some pictures:
CGATCX25GTITURBO
x 16
Re: cx won't start
Unread post by CGATCX25GTITURBO »
Hello, is your car fitted with a T2 engine then?
Neil aka CGAT
1986 CX25 GTI TURBO 1 SERIES 2 'CGAT'
1998 XANTIA 19TD ESTATE
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
1989 CX GTI Turbo 62k miles in a barn since 2001, project started 2023.
jsp
x 12
Re: cx won't start
yes
x 1746
Re: cx won't start
Like those shots of the dash. Almost identical "under the skin" to later BX, which of course it overlapped with.
XM is the same - ECUs do not like depressed battery voltage.
jsp
x 12
Re: cx won't start
pff didnt know that. had to use a huge trickle charger plus new battery.
