How not to do it!
JohnD
(Donor 2022)
x 72
How not to do it!
Unread post by JohnD »
Stuart McB
Unread post by Stuart McB »
Good point this picture.We should all think about safety first. You can see that this guy is sure to have an accident. No welding goggles I ask you. [:D][:D]
philhoward
Unread post by philhoward »
Those don't look like steel toe cap boots, either...
Stuart McB
Are those cross ply tyers? And get a saftey cut out fitted to that welder.
jeremy
x 3
Unread post by jeremy »
bxbodger
Unread post by bxbodger »
Australian I presume?[:D]
Then again, maybe not, at least he's chocked the wheel.........
ACTIVE8
x 6
Unread post by ACTIVE8 »
I think the bloke is about as thick, as the two short planks he is using to hold it up !
What a plonker !
ACTIVE8
x 6
If you want to see some other pictures of things that have been lifted, and what went wrong then take a look at this site:-
http://craneaccidents.com/index.htm
You can view the photo gallery without subscription.
Planning a lift, and doing it safely should be the first consideration before you even attempt to lift it, the pictures are revealing!
Stuart McB
Never ever happened to my Tonka Toys. I always made sure that the load was not greater than the lift capacity of the Tonka LOL.
