Xsara Piccy rear noise
rmunns
x 9
Unread post by rmunns »
I think I am hearing the start of a rear wheel bearing failure on my 2004 Picasso Xsara 2.0Hdi. About 78000miles. A bit of a knocking when first starting when cold, develops into a drone (but does quieten somewhat once I've done 3 or 4 miles).
How can I be sure that this is the problem? If I lift the car will I feel any play? Is it a relatively simple job?
x 1240
Re: Xsara Piccy rear noise
Unread post by Peter.N. »
If you take the weight of the bearings you probably wont feel anything, with front bearings the noise level usually increases when the bearing is loaded i.e. the o/s one when cornering left and vice versa, although that is general its not set in stone.
I would assume that rear bearings would behave the same so try weaving about a bit next time it does it.
