Car is a 2006 Citroen Berlingo Multispace Desire 1.6hdi
I acquired the codes to have a brand new remote key made up, I bought the key from eBay, got the key cut using the code and I've programmed the chip so the key starts the car.
However, I cannot get the remote central locking to work, I've tried every combination of key pressing ignition on 10 seconds wait procedure, just won't bloody work!
What am I doing wrong? Every Google search only gives info about re-sync after battery replacement, what about syncing a new fob?
New key fob remote central locking sync
raynoon
1990 G Peugeot 205 CJ
1992 K Citroen ZX 1.9d auto avantage
1992 K Citroen XM 2.1 SD
1993 L Citroen XM 2.1 SD auto
1995 M Citroen XM 2.1td Exclusive auto
1999 Citroen Xantia Break HDi 110 Exclusive
2000 W Citroen Xantia HDi 110 Exclusive
1998 Citroen Saxo 1.0 Open Scandal
- x 1939
Re: New key fob remote central locking sync
It should be the same.
From memory, and if it's the same as the Xsara and C5, then insert the key into the ignition; move the key to the "ign" position and then press and hold either of the lock or unlock buttons for 10 seconds; return to the off position; remove key.
I might be slightly wrong with the last bit of the procedure and you could try instead: insert the key into the ignition; press and hold either of the lock or unlock buttons and move the key to the "ign" position; hold for 10 seconds and then return to the off position; remove key.
raynoon
Tried that... Even done a BSI reset.... Tried it again, didn't work.
- x 1939
Is there an original second remote control key and does it lock/unlock the car?
raynoon
No original remote key, that the reason I bought a new one. The remote locking is active in lexia too. The key programmed to the car fine and the instructions on lexia were followed.
- x 1939
Was the original key a simple one with no remote? There may be another problem then.
raynoon
Yes, the keys supplied were 2 non remote type, 1 original and 1 aftermarket.
I now have 3 keys, all are able to manually operate the locks and start the car.
raynoon
I have the following information...
2 button remote key, 433MHz Transponder chip ID46 P/N 73373067C
- x 1939
When you say...
...does this mean that, after going through the syncing procedure, when you press one of the buttons that the Lexia shows that it's been pressed?raynoon wrote:The remote locking is active in lexia too. The key programmed to the car fine and the instructions on lexia were followed.
raynoon
Ahh.... Don't know about that... Didn't know you could test that?
Went through the programming procedure, all 3 keys programmed, then it was just some text instructing how to re-sync the fob for the central locking.
- x 1939
No, I thought that you were telling me that. It may be possible, I don't know as I've never looked for it.
Without an already working remote we don't know where the fault lies. The new key may be faulty, maybe just the battery even; the synching process might have failed; the receiver on the car may be faulty, etc.
A Lexia session beckons methinks!
