type of antifreeze
x 5673
Re: type of antifreeze
It's an education!
If only I could remember 1/100 of it :(
x 2000
Unread post by Stickyfinger »
So, it an Engine we have in contact with water
Steel
Iron
Rubber
Silicon
Butyl Rubbers
Do we have: ?
Aluminium
Brass
x 1751
Yes, and probably.
And copper, maybe zinc, possibly the odd bit of magnesium alloy . . .
All those mixed metals also form the basics of a battery, and electrolytic reactions (whereby metals disappear, and gases are produced), and so one of the functions of coolant mix is to stop this dead. (Actually, I believe it's worse in CH systems, with the vast amounts of copper there.) With coolant mix, the anti-freeze function is the least of jobs it does - depending where you live, of course.
x 695
Unread post by Mandrake »
Stickyfinger wrote:Fernox F1.....that's the stuff to use. We will not guarantee our radiators without it's use. (And we can test for it)....Avoid Sentinel
Hmm...
As someone who already has two bottles of Sentinel X100 and X200 sitting in the garage for use later this year, would you mind explaining what you think is wrong with Sentinel ? Or is it just one of those "I prefer this brand of oil" opinions... ?
x 2000
Experience.
I have never in 15 years had a problem with Fernox, I have had quite a few with Sentinel, I do not sell either.
x 695
Well that's annoying, when I've already bought it.
Did a little googling of Fernox vs Sentinel, didn't really find anything other than people's opinions although I thought this test was quite interesting:
http://wiki.diyfaq.org.uk/index.php/Corrosion_Inhibitor
x 2000
Mandrake wrote:Well that's annoying, when I've already bought it.
That is interesting esp as "our" systems have a large amount of Cast Iron.....more than a system with pressed steel rads. The blackened surface and clear water is exactly what we get. With the "other one" I have found rusted areas and stained water..
I will stick with the Fernox F1 recommendation for a system with Cast Rads on it I think.
Jaf
x 42
Unread post by Jaf »
Well I have idea about coolant except when I changed it this year I went from mid range to high range coolant. Green to pink (fully flushed). It has the engine running a little warmer in the winter and a little cooler in the summer, so I am impressed.
Fred, a silver 1998 1.9TD SX Xantia.
Gwin, a white 1994 1.1 AX.
x 695
How would better coolant make the engine run warmer in the winter ?
x 1940
You can make water wetter by reducing its surface tension. This improves its cooling ability.
http://www.superstreetonline.com/how-to ... additives/
Of course you could just have moved a ton of crud when you flushed the system through!
