Synergie loose spring in engine bay
ahearder
Hi could anyone please tell me where this spring is meant to be connected to and what is it for?
ahearder
Re: Synergie loose spring in engine bay
Having trouble adding the picture, how do I upload one?
- x 6947
You can't upload a picture here, but you can link to it. You'll need an image hosting site like photobucket or similar - create an account (there are free ones with a fair bit of space) and then upload to there, click the image, then click the format you want and it will create a url to the image, then you can paste the URL here and it will display your work of art!
https://secure.photobucket.com/register
Or see the Forum post here: http://www.frenchcarforum.co.uk/forum/v ... hp?t=35470
ahearder
Great thankyou,
- x 6947
Looking up another 1.9D, this is what I can see from the Diags:
Injection Pump Detail - Electro Valve
Injection Pump Bracket Detail
Accelerator Cable Detail
chinkostu
- x 30
theres usually a damper there, that doesn't look original, almost like someones bodged it? The usual job is to remove them as they only act to slow the return of the throttle plate (if thats what its called?)
similar to this (same bosch pump ignore the VW badges!)
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
- x 6947
Couldn't believe I was actually seeing a shock absorber on your pick - those VWs must have a really bad vibration issue then!
But as you can see from the service docs for the 1.9D Synergie, there isn't any sign of a damper shown anywhere - I also looked at all the other parts diagrams, but nothing to indicate one of these IIRC.
ken newbold
- x 4
My 806 and the Ulysse did have one at some time or another, but longs since gone, just the ball now where they used to fit. I'm pretty sure my spare engine that came out of a Ulysse stil has one fitted.
1998 1.9td Peugeot 806 (Red shed 2)
2004 Citroen C3 1.4HDi
2003 2.2 Pug 807, Gone and never again!
I'd guess that the original return spring (coiled under the lever) has failed and the one in question has been added as a substitute.
chinkostu
- x 30
The thing is, it isn't a return. many cars have them removed! it simply damps the decellerationGibbo2286 wrote:I'd guess that the original return spring (coiled under the lever) has failed and the one in question has been added as a substitute.
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
ahearder
Thanks for the reply's, Could anyone tell me what the small dial is below the rev counter?
ken newbold
- x 4
oil level indicator, only operates for a few seconds when ignition is switched on, then goes off
ken newbold
- x 4
- x 6947
Way to go - your mysterious spare shock absorber!
