Xantia crankshaft oil seal and clutch
- x 3296
Re: Xantia crankshaft oil seal and clutch
It is not unknown for the ball joint to hang onto the wishbone with a fair degree of grip. A trick that Citronut showed me was to look at the wishbone (close to where it fits with the ball joint), and you will see a couple of widening points. These (Malcolm told me) are where you can whack the wishbone with a decent hammer so as to separate the wishbone from the ball joint stem (which is slightly tapered). It did work well on Gracie.
lazza
Ah i think i see where i'm going wrong- To "split" the balljoint means separate it from the wishbone- right??
I was thinking of "splitting" as when you have to remove the ball joint entirely- which is not the case
Am i correct?
Am i correct?
(1996 Citroen Xantia 1.9TD LX with aircon)
Living in exile in Spain
Running on 100% veggie in summer
- x 8409
Yes, if you take the wishbone off you don't need to Larry but that's going about it the hard way - far easier to split the balljoint and leave the wishbone in place...
lazza
yes i meant you dont have to undo the ball joint completely, just split it from the wishbone
- x 8409
Yes, precisely Larrylazza wrote:yes i meant you dont have to undo the ball joint completely, just split it from the wishbone
harryp
- x 73
I find that no matter how tight, the hub nut comes off easily with my Clarke Impact Driver. Car on stands, wheels off and the unheld hub rotates about 1/4 turn. Amazed me at firs
t. No excessive torque, bars, damage etc. I always used to worry when jumping on my breaker bar
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
lazza
HI- dont have an impact driver, but good to know.
Managed to get gearbox off yesterday so that's good. I now need to take clutch and flywheel off. Problem is I dont have any flywheel locking device-
any tips on methods for locking flywheel to get the nuts off?
also, should I renew all the nuts on refitting?
Cheers
Larry
Cheers
Larry
- x 8409
You need one of these Larry:
http://www.ebay.co.uk/itm/Peugeot-Citro ... SweW5U9IrL
I've used one to great effect... Last used when I did Davie's clutch on his Activa...
lazza
Mmm The problem is I wanted to do the job today... is there no other trick?
- x 8409
Anything that will lock up the ring gear will do Larry... A big chisel or pry-bar jammed in the ring gear teeth but you'll need assistance...
Do not try locking up using the timing hole. Damage will result!
Note that the flywheel bolts should be replaced with new ones and Loctite applied. It is not recommended to reuse old flywheel bolts...
lazza
OK thanks, maybe I'll postpone the next steps and get the proper tool
- x 8409
I would, and new bolts... You'll find these already come coated with Loctite...lazza wrote:OK thanks, maybe I'll postpone the next steps and get the proper tool
Last thing you want is for those to fail after it's all back together....
lazza
HI
Well the flywheel locking tool finally arrived so i'm back on the case.
However I've three questions-
- Is it normal that the bellhousing be layered with such a layer of oily gunk?
- Should I replace the clutch lever plastic end-bush whose locking clip seems to have snapped off? Can you buy these parts?
- Should I replace the input shaft oil seal as i'm in there, just in case?
Cheers
Larry
Cheers
Larry
- x 1490
1 No - could have come from the crank seal as it's leaking or the input seal - does it smell like g/box oil?
2 Yes
3 yes
2 and 3 parts are available from the dealer, but also from ebay in the UK, and they are not dear.
2 Yes
3 yes
- x 8409
Well done and good work! Please the crank locker worked OK...
Yes and yes Larry.. Yes in that as you have a leaking seal the mess is to be expected and yes, replace those nylon bushes. They cost pennies and can make a difference to clutch feel..
Replace the drive shaft oil seals and the input shaft seal just in case it's that one leaking too maybe...
