Oh well Back in the 2cv once again.
Sean602
Re: Oh well Back in the 2cv once again.
Unread post by Sean602 »
...any way
Hows the 2cv?
Im pressing mine into use as a van because the Dispatch has serious electrical gremlins with what seems to be the immobilizer.
Sean
kissing the lash
white van (turbo, computer and built by Citroen, what could possibly go wrong!)
orange 2cv
blue 2cv( been to the Sahara and back)
red Dyane( in bits)
Skoda (thank goodness there is a teutonic vehicle on the drive)
Stainless Siemens fridge freezer
daviemck2006
x 485
Re: RE: Re: Oh well Back in the 2cv once again.
Unread post by daviemck2006 »
CitroJim wrote:That sounds like quite a catastrophic failure in the gearbox Nigel...
A little interesting it has happened so soon after the clutch replacement...
One thing I've noticed in the past is that bellhousing bolts sometimes work loose after a clutch change unless well done up...
On ones I've done recently, including Davie's) I always use a torque wrench and double-check them now...
Not saying it is that for a moment but always worth checking them after a few hundred miles of such major work..
That goes for yours too Davie ;)
A few hundred miles?????? It's mote like a few thousand already! 600 miles to get home, a few times in and out of Aberdeen, and now back down to Peterborough now! I'd better order a new clutch, it will be worn out by now again! Espically as you made a 3mm plywood one [emoji23] [emoji23] [emoji23] [emoji23]
Sent from my SM-T705 using Tapatalk
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
x 8437
daviemck2006 wrote: it will be worn out by now again! Espically as you made a 3mm plywood one [emoji23] [emoji23] [emoji23] [emoji23]
I did use high quality plywood Davie :wink: :lol:
x 3298
Proper marine plywood, 9mm, and correctly seasoned. It should last all of, oh, 6 months of careful driving! :-D
x 8437
Hell Razor5543 wrote:Proper marine plywood, 9mm, and correctly seasoned. It should last all of, oh, 6 months of careful driving! :-D
And I varnished it...
x 3298
3 coats of Blackfriars Yacht Varnish, allowed to dry and then sanded between coats, I take it? That should add another 6 months then. I hope it wasn't too heavily polished, otherwise it will start slipping! :-D
x 8437
Hell Razor5543 wrote:I hope it wasn't too heavily polished, otherwise it will start slipping! :-D
No, I used matt :wink:
falling-out-with-my-car
x 25
stone chip gives it more grip than Matt I find :lol:
x 25
Sean602 wrote:...any way
Hows the 2cv?
Sean
Hmm its nearly MOT time for the little 2cv and I just know its going to fail
on the offside rear breaking it always does.
fitted a brand new hub last year to get it through its test and it passed.
jacked it up yesterday to check all was ok and the hub was wobbling.
so I tried to tighten the hub ring nut and even with a half inch drive ratchet handle and a five foot long
steel pole I couldn't get enough pressure on it to tighten the dam thing up.
its going to need some thought this one.
daviemck2006
x 485
That's why it's slipping already! Must have used gloss varnish [emoji13] [emoji23]
Peugeot boxer 2016
In the family
x 3298
CitroJim said he used matt varnish!
x 5678
With sand in it for improved grip and durability :twisted:
x 3298
People who live on narrow boats normally mix sand in paint, and then use it on the gunwales and the roofs of the boats to provide grip when they get wet. Mum does on The Black Cat.
x 8437
I always put sand in gearbox oil - help give the synchros a bit more friction ;)
x 25
Used to put old cut up stockings in the old Ford (sorry didn't mean to swear)
gearboxes to make them quiet. 8-[
