Synergie fifth gear issue
ahearder
Unread post by ahearder »
Hi everyone just bought a 1999 1.9 td synergie and when I try to select 5th gear theres just a grinding noise like its not there, anyone got any ideas why this is?
spider
x 77
Re: Synergie fifth gear issue
Unread post by spider »
Does reverse work OK ?
With the engine off ( ! ) depress the clutch and try (carefully) to select 5th gear. Will it go in and appear to select OK ?
The noise points towards internal issues, although its on "the end" in the extension housing from what I recall, it may be quite annoying to try to sort it in situ.
Andy.
x 1751
Fifth gear vibration and wear is not unknown on a good many vehicles, where 5th speed cogs are on an unsupported "outboard end" of the shafts (i.e. bearing only on one side of the gears). Usually accessible by removing box end cover. Dates back to when a fifth gear was a bit of an afterthought.
x 1240
Unread post by Peter.N. »
I repaired 5th on an CX that had lost synchro by removing the endplate, not the easiest of jobs but certainly easier than taking the gearbox out!
ken newbold
x 4
Unread post by ken newbold »
Not heard of a 5th failing on one of these boxes, usually 1st, however.......
1998 1.9td Peugeot 806 (Red shed 2)
2004 Citroen C3 1.4HDi
2003 2.2 Pug 807, Gone and never again!
x 1751
Ken,
You're probably right. My comment was about 5-speed boxes in general.
C.
ahearder
Thanks for the replies, all other gears are fine and it will select fifth when engine is off
spider
x 77
white exec wrote:Ken,
C.
I know what you mean, its in the extension itself usually with reverse gear.
Andy.
x 1456
It's not unknown on this box (assuming it's a BE3). 5th is outside the main casing and suffers from 2 issues - either the shaft nut comes loose, or low oil level causes the gears to break. Seems more common on motorhomes - perhaps because of the added weight. It should be sortable in place.
Here's a thread with similar issue:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=52099
Citrojim's box rebuild info which shows how to get the 5th gear off: http://www.eastment.net/be3%20gearbox.htm
