Marc,
Thanks for the reply that makes sense.
Where do you get your knowledge of the x7 from, I'm just curious?
Kenny
Activate aux connection on c5
Moderator: GiveMeABreak
- KennyW
- My Cars: Current Citroen's
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Xantia 2.0 90hp estate
Xantia 1.9 TD estate - x 132
Re: Activate aux connection on c5
C5 x7 2.0 HDi 160 hp Estate exclusive, the newbie
C3 1.4 petrol (SWMBO)
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5723
Well I have an X7 for starters Kenny ( ) and I researched the DAB options quite a lot for my vehicle, but unfortunately the AutoDAB unit isn't compatible with the NG4 (Navidrive 3D) system I was told, so that blew that one away! Plus having a 1st and 2nd generation C5 before the X7, I undertook a lot of research into the differences and options before I finally found my X7. I also did a lot of research on the newer Navidrive 3D, as I had the RT3 Navidrive on my previous C5.
Going back to your issue - in this video they are fitting an AUTODAB unit, - as mentioned you have the EZi DAB unit. However, from about 35 seconds into the video below, you can see the aerial that is needed for really good reception - noting that the black tab section needs to be attached to the metal of the pillar. If you don't have one of these types of aerials, the reception isn't going to be great. Was this type of aerial fitted?
- KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
It was the standard issue with the Easy Dab
Kenny.
Kenny.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Well they do sell these digital aerials separately Kenny if you wanted to upgrade it, quite reasonably priced.KennyW wrote:It was the standard issue with the Easy Dab
Kenny.
- KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Do these aerials give a better reception?
Kenny
Kenny
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Yes Kenny, they are designed to receive digital signals (which DAB is of course). There are several 'Alpine' aerials for this model, but the KAE242DA is recommended for the EziDAB.
Here's one link:
http://www.ebay.co.uk/itm/Alpine-Kae-24 ... 2020782299
You have a DAB transmitter in your area - which should help too:
https://ukfree.tv/transmitters/dab/Peni ... /irt635830
Of course DAB can be a bit of hit & miss for a lot of people - but I get great reception from the DAB radio in the house - and that just has a dangled aerial cable behind the unit - so nothing special and that's in rural West Wales too.
One thing DAB is really susceptible too is any sort of interference from 12v car accessories - unplugging these can instantly improve DAB signal it has been widely reported - again I suppose it is down to how well these are shielded.
Here's one link:
- KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Thanks Marc for the link,
I found out to my cost the connection on the Easy Dab is not the same as the SMB fitting but very slightly different.
Kenny
Kenny
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
One other thing to check out Kenny is the windscreen. There are known issues with internal screen aerials attached to windscreens with any sort of athermic / heat-reflecting coated or built-in metalic windscreen heaters, as these can interfere with the signal. AFAIK Citroen haven't (not on the C5 anyway) used heated front windscreens (the type that are electrically heated such as Ford use), but they are definitely athermal.
The black mottled coating around the rain / light sensor and around the edges of the windscreen do not contain any coatings, so should allow signals through (i.e. some people use these areas for placing their toll cards for automated toll barrier card readers to pick up the signal).
I know this was an issue for some C6 owners with DAB radios. Some have actually had an external aerial fitted (either roof-mounted or glass mounted on one of the rear quaterlight windows). It really depends on the GPS / DAB device, the aerial specification used, the type of windscreen glass and of course the DAB signal in the area to begin with; but anyone considering a DAB 'upgrade' will need to take this into consideration.
- KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Marc,
There is a roof mounted aerial which fits the Easy Dab but how and where would you run the cable?
Kenny
Kenny
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Kenny - I never got as far as that - after finding the unit I wanted wasn't compatible, I didn't venture into the aerials in any great depth. I do know though, that on the X7 there are 22 types of Aerial cable, 2 types of aerial wire and 7 types of aerial base - all dependent upon the Audio Head Unit fitted, whether there is an independent Telematic unit, a Service Module, GPS, Single or Dual Tuners fitted etc., etc. I only mention this in case you are thinking of replacing the existing aerial - so need to be sure that all the existing wiring and connectors will hook up.
If you are thinking of fitting a separate roof aerial, then of course it should be a matter of feeding back through the headlining, down to the passenger side, avoiding airbags etc. - I've pulled up the intermediate wiring harness diagrams for the X7 - which just about shows the aerial wiring and where it travels to. It seems that it travels back down through the passenger side pillar and through the glovebox area to the headunit.
- KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Thanks for that Marc,
I was just curious, I am going to explore the options but I still have the original aerial which does work. Once I have given both aerials a go I'll see what's best and add it to this thread for future reference.
Kenny
Kenny
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
That's great Kenny - will surely be useful for anyone contemplating a DAB upgrade in future.
