A head leak between cylinder and water way will not cause mayo, will result in coolant loss though!oli_25_uk wrote:It does have a history of loosing water, not vast quantities, I think most likely due to some hole somewhere expanding when it's hot...
Still pretty certain it's not head gasket, system withstands pressure testing and there is no sign at all of mayo...
Keep the CX or suggestions for alternative?
cachaciero
- x 9
Re: Keep the CX or suggestions for alternative?
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
OnlineStickyfinger
- x 1985
It can do, due to positive pressure in the coolant system when you turn the car off.
cachaciero
- x 9
Stickyfinger wrote:It can do, due to positive pressure in the coolant system when you turn the car off.
Well I guess if the water can get past the rings into the sump then yes, just get the feeling that not enough water would enter via this route to produce "mayo" but I could well be wrong. Anyway if there was a water to combustion space leak a "sniffer" should identify it, wouldn't have too much confidence in pressure checking to find a small leak least ways at the pressures normally used.
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
oli_25_uk
Cheers for all this - just about to pick the car up from the garage (after a new fan temperature switch has been installed (along with other things)) - but I'm interested in this suggestion of a 'water to combustion space leak' - What other symptoms would you expect to see going along with such a leak?
OLIx
OLIx
cachaciero
- x 9
Well there should be combustion products in the coolant and there are sniffing devices which can detect that, believe it's quite a standard piece of kit for many garages. I would look to get a check using such a device if the coolant tests negative for combustion products you could probably forget the gasket. Another thought is that rubber as used in pipes was not of the quality it is today so evaporation through the rubber is a possibility.
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
