Advice regarding Lexia/Diagbox
atr
x 6
Unread post by atr »
Hi all
Received finally the Lexia (chinese clone) there are two cd's - one with the Lexia and pp2000 software and the second several versions of Diagbox
as follows:
v7.57 to 7.58
v7.58 to 7.62
v7.62 to 7.66 (8.02)
v7.66 to 7.74 (8.10)
v7.74 to 7.76 (8.12)
v7.xx to v7.57
since I have no experience with it - please recommend which version should I install (taking into consideration that I intend to use it mainly on the C5).
I also will highly appreciate any advice/guidance regarding it.
Btw - good luck with the voting today.
jimmymarsbar
x 13
Re: Advice regarding Lexia/Diagbox
Unread post by jimmymarsbar »
Does the Diagbox installation disc give you v7.01/v7.02?
The suitability of software for your car depends upon how old the car is - newer versions should be better suited to newer cars.
However, between the versions you've listed, I doubt there'd be much difference in it
The Ace
Unread post by The Ace »
Actually if you read the document that came along with the CD, it clearly says that you have to install (or upgrade) all of the available versions. The document contains VERY specific steps that you MUST take with every single executable found in the CD.
If I remember correctly, you should find a very big executable, which should be version 7.0x, which you install first. Then you must execute every single file according to their version, and -more or less- perform a reboot after every file finishes installing. Then you open DiagBox in order for it to update to the next version, close it immediately (your web connection should be deactivated during this time), and perform the same actions with the next executable.
If you can't find the doc I'm talking about, I can send you mine when I get back in the afternoon....
spider
x 77
Unread post by spider »
Mines on 7.0.2 although I do need to update it (it started at that version as that's what came with it!) but it does not (appear) to like Windows10 it seems. It was fine on Win7 however but I've not used it for ages until the other day.
Agree with above, ensure that you do not have any internet access when you are doing the update etc, you do not want it to try to connect.
Andy.
x 6957
atr wrote:Hi all
as follows:
v7.57 to 7.58
v7.58 to 7.62
v7.xx to v7.57
Chaps - Just to be clear!
I've undertaken a fair bit of research on this and I wouldn't recommend upgrading past 7.58 at the present time. The reason being that past 7.62, subsequent releases of Diagbox have gradually removed telecoding features from the offline versions of the software on gradually more vehicles, with the move toward having all the telecoding undertaken online - which of course you cannot do as these are clones! Atetmpting to online telecode will deactivate your software without a valid PSA server dealer code and login.
V7.58 covers PSA vehicles produces at November 2015 and is widely accepted as a stable version. There is an automatic desire in us to want to 'upgrade' everything - but that is not always the right thing to do when dealing with cloned hardware and patched software, working outside the dealer network of course.
@ ATR: The age of your C5 will use the Lexia interface anyway - which is accessed from the Diagbox front end.
I have started to compile a version change log of Diagbox on the Forum Wiki here for more information on changes:
http://www.frenchcarforum.co.uk/wiki/Di ... 9/7.06_On)
Without wanting to regurgitate everything on the main Lexia Diagbox thread, I downgraded back to 7.58 as a result of loosing telecoding options on my C5 X7. Most of the newer versions or Diagbox are being shipped with V8 - but even some of the suppliers don't realise the telecoding issues (except easydiagnostics) as they don't generally use the software! Users are finding that more and more of the car vehicles in each release of Diagbox have removed all the offline telecoding - so it is hit and miss as to which vehicles these are. :)
