Vented Disks vrs Solid disks
x 1998
Unread post by Stickyfinger »
OEM quality, which would you have ?
BenC5HDi
Not Mike
x 45
Re: Vented Disks vrs Solid disks
Unread post by BenC5HDi »
Vented, every time. Went from solid to vented on a couple of cars, the difference when using the brakes enthusiastically is very apparent. They take much longer to fade. I've got a set of vented and grooved discs to go on the Berlingo when the pads finally wear out now it's been remapped and the brakes are actually being used now.
van ordinaire
(Donor 2017)
x 400
Absolutely, grooves MAY be worth the extra - but I'd draw the line at drilled (for road use, at least).
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
Jeep XJ Cherokees x 3 :?
'96 Cadillac Eldorado
'99 Cadillac STS :|
daviemck2006
x 485
Unread post by daviemck2006 »
Definately vented for me. Even the lowly 107 has vented discs. I've never had grooved, maybe I should have tried them on the activa.
Sent from my SM-T705 using Tapatalk
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
BenC5HDi
Not Mike
x 45
Re: RE: Re: Vented Disks vrs Solid disks
van ordinaire wrote:Absolutely, grooves MAY be worth the extra - but I'd draw the line at drilled (for road use, at least).
My C4 VTS had vented and grooved discs on it, the brakes were fantastic.
x 1746
No contest - vented is usually OE choice wherever high-performance braking is required.
I'm surprised you actually have the choice . . . If the originals were vented, then the 'choice' of switching to solid (presumably an after-market item) is really a 'downgrade', I would assume.
x 1998
Nope, solid OEM disks....vented are for C5 as well. But the Vented disks seem to cause people warping problems.
spider
x 77
Unread post by spider »
Some models "appear" to have air scoops to provide venting for the um 'vents' in the vented discs. 206 does from what I remember there is (or sometimes is!) a bit of plastic to try to channel a bit of air that way.
If I was building something I'd prefer vented. I not personally go with grooves / drilling as I think that (for me at least) a step too far, plus to obtain them like this costs more too.
Generally (depending on what you're up to) you may find a higher spec / engine in that car model has vented so you can use those parts to replace the solid. Likely to want calliper carriage as well (I know you know this!) , if you are unlucky possibly hub too.
Talking of brands, for 'non genuine' I used to usually fit Apec stuff as (1) it was readily available nearby and (2) the quality of it appeared very good.
Andy.
elma
x 284
Unread post by elma »
Vented front and solid rear. Grooved and drilled are for racing cars, road cars don't make enough heat in the brakes for them. Any benefits from them are psychological.
I like Mintex, road and race pads are decent. Aep are my choice of upgrade callipers.
BenC5HDi
Not Mike
x 45
elma wrote:Vented front and solid rear. Grooved and drilled are for racing cars, road cars don't make enough heat in the brakes for them
Really? I used to often get the brakes smoking on my Impreza and Audi TT, and they fade like hell on the Berlingo if it's driven hard..
elma
x 284
I would've shared your opinions 3 years ago. I was proved wrong in a most scientific way by a race car designer. In doing so he thought me a lot about using the brakes correctly as well.
Quality tyres, pads and discs matter much more on a road car than grooves, drillings, ceramics and high boiling point fluid. If anything these "upgrades" reduce performance as they can't get to operating temp at road speeds.
x 1998
Just to note....I have not had any fade yet.....but I have seen vented OEM ones at a good price.
elma
x 284
By OEM do you mean Citroen (good) or some other brand (variable, what brand)?
Got to watch out for fakes as well, one of my better local factors got a batch from India that were fakes of a quality brand. They warped on installation then warped more on braking.
x 1998
Reported as Citroen ones....Xantia/C5
x 1746
I need to fit disks and brake pads so rarely (both Citroen and Toyota) that I only fit genuine OE items. Any saving is really not worth bothering about, as even main dealer prices are now 'competitive' in order to achieve any appreciable over-the-counter sales. Prices charged to the customers having their vehicles serviced are another matter entirely!
