- x 1995
Re: I am an Activa owner...a V6 and I am an addict
Good point.....I could put a drain into it to cure that problem maybe ?
- x 695
I don't think it's just draining of the dip at the bottom that's the issue - if you imagine throwing a cup of water into the end of the pipe with the engine running (don't try this at homeStickyfinger wrote:Good point.....I could put a drain into it to cure that problem maybe ?
On a non-porous pipe I think you'd find that that entire cup of water would end up sucked into the engine even if there was a small drain hole at the bottom. Another problem with a discrete drain hole would be that it would almost certainly cause a whistling/whining noise - even a small leak between the two halves of the air filter box or around the edge of the air filter (had this happen to me with a distorted filter) makes a noisy whining noise at certain RPM.
- x 1995
? If that is the case.....why are the other Xantia types not fitted with a similar hose set up ?
- x 1995
Google say: tubing is called a "shannon tube", on the Rover forums it is speculated the fabric is for sound proofing ?....thoughts ?
elma
- x 284
Have you a link to the thread? I couldn't find it and I'd like a read because I don't think that makes sense.
A big gulp may be 2 pints? I can't imagine that leaving through the pipe walls before meeting the engine.
Performance cars use woven silicon pipes so I can't see the harm in a non porous pipe myself.
I'd missed this page when I wrote this post, it makes more sense if you imagine it at the top of this page.
elma
- x 284
Possibly this came up when I was trying to work out what was going on.Stickyfinger wrote:Google say: tubing is called a "shannon tube", on the Rover forums it is speculated the fabric is for sound proofing ?....thoughts ?
- x 1995
- x 8409
Good point about the porous nature Simon... Alasdair, you may be best off using a piece from a lesser Xantia and modifying it...
- x 1995
I would Jim....but those are plastic, thus non-porous so why bother ?
That is the conundrum for me. Why would it be so important for the V6 to be a porous design if all the others are not ? What is so special about the Air flow into the V6 ?
- x 1463
I don't think the porosity has anything to do with water ingestion. I think it is for acoustic silencing, which you probably don't care too much about.
- x 1995
That is what is said on the Rover forum......(see link)
- x 1463
This is the corresponding air intake hose for the ES9J4 XM. Note the baypass which is clearly there for acoustic tuning.
- x 695
I'm assuming that fabric join that dips down in the middle does hang down when installed in the car ? Surely allowing water to escape safely is part of the design of it, if albeit not the only purpose...
Otherwise that would be a massive water trap.
BenC5HDi
- Not Mike
- x 45
Does anyone have a spare to chuck a couple of pints of water in, and see how quickly it drains out?
- x 8409
All Xantias have the fabric ones, not just the V6...Stickyfinger wrote:I would Jim....but those are plastic, thus non-porous so why bother ?
