x 2000
Re: I am an Activa owner...a V6 and I am an addict
Unread post by Stickyfinger »
88mm will do .....and I can lay my hands on one of them :)
x 8370
Hell Razor5543 wrote:
Stickyfinger wrote:I feel the need for an Alloy tank Jim :)......the hunt is on
Preferably with a 105 calibre barrel, so as to dissuade Citroen from making them NFP!
:rofl2: :rofl2:
A bespoke rad outfit should be able to make you a lovely TIG welded aluminium job Alasdair :D
x 2000
My thoughts exactly Jim, it would solve the problems with the tanks. I am half tempted to get a de-gas tank made at the same time.
I will ask James tomorrow about local guys who can make them........so IF anybody would like to join in on an order, please let me know. and I will find out about costs for multiple units.
x 8370
Good idea on the degassing tank as we know they're like rocking horse poo now and NFP...
Remember what Mike said that the angles are critical ;)
x 2000
I have an old one (split) as a pattern part.....internals as well would need to be replicated
I said REPLICATED not replicant !
x 5673
These guys could do it:
x 2000
Well I decided to pressure test the header tank. Set it up and pumped it to 5.PSI with 80% filled with water.
I used talc powder so as to see any seeping (the white stuff) .....turns out it really was not needed :).....leaking at about 6 points along the join.
So I cut it open to see what was inside.....well that is very complicated.
The brown plastic insert slides unto some groves. On the edge (lower right in the pic) is a cut out that allows water to flow into the top compartments as it also can via the hole in the center.
x 8370
Certainly went like a good 'un Alasdair!
superloopy
x 19
Unread post by superloopy »
Count me in on the ally header & bubble tanks sticky ...
Sent from my LG-D855 using Tapatalk
Mike
x 2000
Will advise on prices for them......at least we have lots of pattern parts to copy :)
x 695
Unread post by Mandrake »
What is the original joining method ? Plastic weld ?
Can it be glued instead as a repair with the right kind of glue ?
x 2000
HOT melt by induction and pressure to join by the look of it. No mastic present.
My thoughts on it is that the constant cooling/heating cracks the join which is a brittle area due to the heating/melting of the plastic.
When melted and "force flowed" by the pressure used to join the two parts together, the structure of a carbon filled plastic will change vrs the rest of the unit which is pressure cast/formed.
This will make a stressed area as it cools.
I would say it was a poor design/manufacturing/material choice for this type of unit. I would think they choose the carbon filled plastics due to heat at the firewall generated by the exhaust below rather than use the clear types seen on other engines which would go brittle. Modern joining mastics and metal clips may be a solution to the problem, I will be looking at that as well...metal clips (x10 ish) being better than bolts at applying an even pressure to the flange.
This type of product...
x 2000
x 8370
Cracking picture Alasdair!
elma
x 287
Unread post by elma »
That is a superb picture.
