Fog/spot lights on C5 mk 1
hirsty
x 9
Unread post by hirsty »
My C5 has a mesh lower grill rather than the plastic ones and I can see holes ready cut for fog/spotlights.
I assume the wiring is also in place as it was for my upgraded electric leather seats. Anybody got the spots and how difficult to fit. :)
hirsty
98 Xantia Mk2 2.0 16v Auto Exclusive 160k + Now gone to Citroen Heaven
2004 C5 Mk 1 2.0 8V VTR Estate - current. Now with leather.
x 6955
Re: Fog/spot lights on C5 mk 1
Is it the MK I to 2004 or MK II facelift 2004-2007?
I guess you'll also need the correct lighting Stalk with Fog Light Barrel.
waynedance
x 8
Unread post by waynedance »
As far as i know there is no fogs fitted to lower bumper on the mk1. Fogs are built into the headlights on non xexon models and the xexon models do not have them.
I have fitted day time running lights in my lower bumper.
Sent from my Lenovo TAB 2 A10-70F using Tapatalk
Volvo S80 D5.........
C5 2.2HDi Exclusive 2003 manual (now gone).
2009 Renault Megane, the misses drive.
Had a 1988 BX 19TRS Auto many moons ago.
Forgive any spelling mistakes, it's the phone not me.
x 1987
Unread post by Stickyfinger »
Correct, Mk2 (facelift Mk1) had fogs under the bumper, mk1's in the lamps
hirsty
x 9
This is a mk 1 up to 2004 and has the fog lights in with the main beam and the stalk rotates to turn them on.
I also have pre cut holes below the bumper for something??. Any clues .
hirsty
x 6955
That's why asked which model you had. I think you are mistaking the lower grille sections for fog light blanks when they are actually just left and right air grills.
x 1987
hirsty
x 9
According to the Haynes BOL, the facelift had fog lights fitted as there is a section on changing bulbs which tells how to change them. It appears I have a facelift front valance. Closer inspection shows some overspray which suggests possible damage repair with a facelift part. Is this possible?
hirsty
waynedance
x 8
Can not see how a mk2 front bumper would fit on to a mk1 without replacing the bonnet, Lights and god knows what else………. If that's what you mean?
Do you have car from pic 1 or 2? Simples
hirsty
x 9
Car is identical to pic 1
hirsty
x 6955
hirsty wrote:According to the Haynes BOL, the facelift had fog lights fitted as there is a section on changing bulbs which tells how to change them. It appears I have a facelift front valance. Closer inspection shows some overspray which suggests possible damage repair with a facelift part. Is this possible?
hirsty
The MK II (facelift) did have fogs in the bottom valance section as per bottom photo. I don't know what you have fitted but your mark one isn't designed for the Mark II type.
