I'm after changing the interior bulbs to LED the side pillars, ones above the doors/glove box/boot and footwell lights, keep getting different search results of different sizes and design for each area. Don't trust the bulb checking sites as they seem to place the xantia in 3 categories of year 93-97/97-99/99-01 is that right.
Cheers
Xantia S2 interior lights
xantiagreen
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
96 Xantia 2lt 16v Sx Olive green
01 Xantia 110 Hdi
Storm Grey (SOLD 4/11/18)
Temporarily driving Polo 1.9sdi
All I want is a Bx Gti or 16v!
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
xf1ref
- x 11
Re: Xantia S2 interior lights
Hi, all the bulbs are the same T10 3W for footwell and glovebox and 5W for boot and pillars.
xantiagreen
Thanks for the info is it T10 5w fpr the ones under the gtab handles passenger side, how do i take thepillar light covers off and the one under front passenger grab handle.xf1ref wrote:Hi, all the bulbs are the same T10 3W for footwell and glovebox and 5W for boot and pillars.
Cheers
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
OnlineHell Razor5543
- x 3295
The pillar lights are held in (IIRC) by spring clips and a tab. I carefully used a blade screwdriver to get them out, but I cannot remember which way I did it (sorry!).
xantiagreen
I daren't touch mine as I'm pretty sure the tabs will be brittle and snap off, so I'll be off to the local scrapper looking for a S2 xantia do carry out an autopsy on pillar light and the ones above the grab handle.Hell Razor5543 wrote:The pillar lights are held in (IIRC) by spring clips and a tab. I carefully used a blade screwdriver to get them out, but I cannot remember which way I did it (sorry!).
Why do some of the bulb sites even ebay display the bulbs as festoon for the xantia interiors?
Cheers
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
MikeT
- x 232
IIRC, pillar light clips are top and bottom and are very robust and require a fair bit of easing force to release. I always went in from the top.
- x 3295
Thinking about it, I thing I went in through the top, as the wiring and plug come in from the bottom (and will not allow the bottom to pivot out).
xantiagreen
Will I have to get canbus free led/cree or will any one of them fit without problems.xf1ref wrote:Hi, all the bulbs are the same T10 3W for footwell and glovebox and 5W for boot and pillars.
Cheers
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
- x 3295
I would not get LED lights, as they will be focussed forwards (in relation to the connector), and while this is OK for the sidelights, for interior lights you will need light coming out from the sides of the bulbs.
xantiagreen
Ahh so does the bulb fit in vertically with the tip of the bulb facing upwards or downwards, I was looking at the bulbs below so not 100% sure which ones are okay..Hell Razor5543 wrote:I would not get LED lights, as they will be focussed forwards (in relation to the connector), and while this is OK for the sidelights, for interior lights you will need light coming out from the sides of the bulbs.
http://www.ebay.co.uk/itm/T10-1-5W-CREE ... -RBQs5RwJw
http://www.ebay.co.uk/itm/151759772607?var=450956209930
http://www.ebay.co.uk/itm/301907694390?var=600715468895
http://www.ebay.co.uk/itm/PHILIPS-XTREM ... SwFqJWqMbT VERY PRICEY!!
http://www.ebay.co.uk/itm/5-SMD-LED-XEN ... TjnKNHjmmA
http://www.ebay.co.uk/itm/2x-T10-501-19 ... SwMmBV3yuF
Sorry about the long list..
Cheers HellRazor
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
- x 3295
1 and 4 may not work well (light from the tip), but the others look like they would work.
xantiagreen
Top man, at least I now know what type of bulbs I need...Hell Razor5543 wrote:1 and 4 may not work well (light from the tip), but the others look like they would work.
Cheers
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
- x 3295
However, I would suggest to pay a visit to your local Poundland. I have got suitable bulbs for £1 a pair, in AA packaging.
xantiagreen
Hell Razor5543 wrote:However, I would suggest to pay a visit to your local Poundland. I have got suitable bulbs for £1 a pair, in AA packaging.
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
