Whats this plug?
elma
x 287
Re: Whats this plug?
Unread post by elma »
The estate (96) did, I removed it. The red one (95) didn't.
x 694
Unread post by Mandrake »
xantiamanic wrote:I've not got one of those although i thought my car predated all of those 'gizmos'.
Does your vsx have a keypad?
Immobiliser keypads were only used in Series 1 Xantia's. Your S1 is 1995 - the 1995 Activa had an immobiliser keypad so it doesn't surprise me that your car has the wiring harness for it.
Only some engines supported the keypad though - my Japan spec 1997 S1 Xantia 2.0i (8 valve petrol) that I had in NZ had no immobiliser keypad, and no alarm either.
x 8175
Yes, black is keypad and the others are for the seat heater control switches...
superloopy
x 19
Unread post by superloopy »
So none are the power to seats?
Simon ... this is my 1995 TD SX not Activa.
Mike
x 694
xantiamanic wrote:So none are the power to seats?
I know that, but I'm pointing out that at least one model of Series 1 Xantia of the same age as yours did use a keypad, you were concerned that your car pre-dates the use of keypads in Xantia's but it doesn't. Hence why it would not be surprising to find an unused cable for it in the wiring loom.
chinkostu
x 30
Unread post by chinkostu »
My SX has exactly the same under the tray. Still no idea what the white plug is.
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
x 1900
Well, no-one has said that that it isn't for powered seats.
x 694
Paul-R wrote:Well, no-one has said that that it isn't for powered seats.
Sorry but it definitely isn't.
The powered seats use a LOT of current, those two small diameter wires would have no chance of supplying that. From memory the electric seats are brown or black with pretty heavy wires. I'll see if I can get a picture of the connectors on mine without removing the seat.
x 1980
Unread post by Stickyfinger »
I will take some pics today for you....I have a stripped seat on a bench at the moment.
superloopy
x 19
Those yellow plugs look pretty heavy to me. Just two wires into each plug.
Sent from my LG-D855 using Tapatalk
Mike
x 694
If you're referring to the yellow plugs under the centre console tray those are probably for heated seats as the heated seat controls go there in cars fitted with them. The heater element also draws a lot of current. The electric seat (for adjustment) don't go via any plugs in the centre console tray area.
My S2 V6 had heated seats but my S1 V6 doesn't so I can't check unfortunately.
chinkostu
x 30
the seat wires also have three wires, as there is a relay in the seat base so they only come on with the ignition :)
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
x 1980
Hope it helps
chinkostu
x 30
thats different to mine Al! ill get the pic now
the yellow plug is the one for the seat power.
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
superloopy
x 19
I've just seen these three plugs .... could these be for the power?
If they are then which is which, any ideas? And why three?
Mike
