Good luck with the project and if you were closer I would offer a hand . I have a yearning for another V6 engined car myself .
Mark
FS: Xantia V6 Activa Conversion Kit for TCT to V6 swap
bxzx16v
- x 34
Re: FS: Xantia V6 Activa Conversion Kit for TCT to V6 swap
DHallworth
- x 163
Just to add my 2p worth.
I used a freight company to courier my engine and box to BL Auto's when my Activa went there for the engine swap. The engine and box on a pallet, with a light wooden frame around it, clad in some thin plywood for protection was weighed by the freight company at 450kg. Just thought I'd give you a heads up as it's almost double what you're basing it on a couple of pages back
A friend of mine who had been looking for an Activa for quite a while bought the green one that was on eBay last week, I tried to convince him he needed this kit but he wasn't having any of it
Xantiamanic, are you going to the CCC Northern Rally this year? My Activa V6 will be there if you want a run in it.
David.
David.
'98 Xantia Activa V6
'00 XM V6 Exclusive
'09 C5 2.7 HDi Exclusive
‘10 C5 3.0 HDi Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
superloopy
- x 19
Surely not 450kg David ... that's some 990lbs/14 = 74 stone (ish) .... must've been a heavy pallet and ply
It IS an aluminium block isn't it?
Mike
BenC5HDi
- Not Mike
- x 45
There's a thread over on the 205 GTi forum with a load of PSA engine weights. The ES9J4 is apparently 215kg complete with ancillaries and manifolds but no fluids. The ML5 gearbox is 50.5kg.
Sent from my SM-N9005 using Tapatalk
OnlineStickyfinger
- x 1980
on average Euro pallets weigh 12-15kg
superloopy
- x 19
Re: RE: Re: FS: Xantia V6 Activa Conversion Kit for TCT to V6 swap
Thats moreorless what i thought although its the opinions of those in the know that really counts here. Anyone able to confirm Davids 450kg figure? That seems mighty heavy to me for an aluminium block. I think it does equate to around the 450lb mark though so maybe that explains it.BenC5HDi wrote:There's a thread over on the 205 GTi forum with a load of PSA engine weights. The ES9J4 is apparently 215kg complete with ancillaries and manifolds but no fluids. The ML5 gearbox is 50.5kg.
Sent from my LG-D855 using Tapatalk
Mike
BenC5HDi
- Not Mike
- x 45
There's a picture on the thread of an ES9 on a scale and it comes in at 182kgs without manifolds and ancillaries so 215 is about right. The figures are apparently taken from workshop manuals.
DHallworth
- x 163
Interesting! Must of been his pallet scale that was way off calibration! He was checking that it was under half a ton and it was so it wasn't really an issue. I'd estimated around 250kg and was gobsmacked when he told me that so it does make sense that it's about half that!
David.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
BenC5HDi
- Not Mike
- x 45
The thread is here... 6th post down has a long list of weights of all PSA 90s motors, the pic of a V6 on a scale is the last on the first page. .
http://forum.205gtidrivers.com/index.ph ... 614&page=9
There's a list of gearbox weights later in the thread.
Skull
- (Donor 2026)
- x 370
xantiamanic Well acquired
Sounds a bargain ... whereabouts are you
...... AND and how come I missed an Activa on ebay
I must have about 10 Xantia searches in various categories
Gary
Gary
DHallworth
- x 163
The Xantia on eBay wasn't advertised as a Xantia or Activa... The title of the auction was just the number plate, it only popped up under "Xantia Related Searches".
A friend of mine bought that car and seems to be very pleased with it.
David.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
Skull
- (Donor 2026)
- x 370
Thanks David
Gary
Gary
