806 gearbox
Barry1
806 gearbox
Unread post by Barry1 »
Hi All
Can anyone tell me where the code is stamped on a 1997 806 gearbox please.
ken newbold
x 4
Re: 806 gearbox
Unread post by ken newbold »
Not offhand no, but petrol or diesel and why?
1998 1.9td Peugeot 806 (Red shed 2)
2004 Citroen C3 1.4HDi
2003 2.2 Pug 807, Gone and never again!
Barry1
Re: 806 gearbox
Diesel and we've got to change it so I want to source the same type.
ken newbold
x 4
Re: 806 gearbox
I've got one here, came out of a 97 1.9TD Ulysse
Barry1
Re: 806 gearbox
Thanks for that Ken but I may live a bit far away to pick it up.
spider
x 77
Re: 806 gearbox
Unread post by spider »
Barry1 wrote:Hi All
You have the BE3/5 transmission (possibly BE4 but it should be the same) On the front, might have to remove a few bits to see it.
Andy.
ken newbold
x 4
Re: 806 gearbox
Barry1 wrote:Thanks for that Ken but I may live a bit far away to pick it up.
keep it a secret then and no one will ever know
spider
x 77
Re: 806 gearbox
Apart from the release mechanism if it comes from a XUDT it should be the same.
Gearing (I think its the final drive really only but I'm not sure) with a HDi 2.0 box is a bit different and does actually suit the XUDT just fine from what I've heard (not personally verified this) , be aware some 'donors' may have either a cable or hydraulic release mechanism and / or a push / pull type clutch, for the sake of simplicity it would be best to get the same as you have now...
Andy.
x 1996
Re: 806 gearbox
Unread post by Stickyfinger »
:rofl2:
Barry1
Re: 806 gearbox
Sorry Ken I live in France I thought it was on my profile SORRY :oops: it is now :-D
Thanks for the information Spider I found a nice Frenchman breaking one today 80 euros he said it was working fine right up till the time the lorry demolished his back end !! (the car that is not his)
On a slightly different note, what a pig these boxes are to get out #-o
spider
x 77
Re: 806 gearbox
You're welcome. :) Good to know you've got one now.
Yes its not very nice to remove is it :( hmm. Oh well.
I don't know if it was me or not but I found the 306TD ones a right £2"£$"£$ to remove too, (bear in mind its the same as the 406 one with the curious clutch arrangement) but I guess lack of space made it more entertaining.
I think if you remove the nearside lower arm you get a bit more room but I never bothered I just struggled.
Andy.
ken newbold
x 4
Re: 806 gearbox
when I changed my gearbox, I made the mistake of dropping the subframe and getting it out from underneath, it would have been easier to pull the engine and box out together over the front.
Barry1
Re: 806 gearbox
The new box is in (what a *******) we put a new clutch in while we were at it but is there a way of resetting the auto adjust on the cable as the clutch bites just off the floor.
ken newbold
x 4
Re: 806 gearbox
Keep pumping the pedal, could take up to 20 or 30 presses
Barry1
Re: 806 gearbox
Thanks.
