Tool to remove oil/fuel filter
x 1955
Re: Tool to remove oil/fuel filter
bobins wrote:If you're talking about having trouble removing the fuel filter, then some of the filters are best undone with a socket like this:
Laser tools part 5270 - other manufacturers are available.......
Are the cut-outs to clear fuel pipes? It doesn't specifically say so but I presume it's 27mm.
Funnily enough I ordered an ordinary 1/2" drive 27mm single hex socket (Silverline, £3.06 inc dely) the other day for the oil filter on my daughter's Pug 206 and I believe that my new C5 has the same type of plastic oil filter casing. I used to borrow my brother's 27mm deep socket on the odd occasion I needed one but, as it's really his wheel nut socket for his Land Rover, he gets a bit twitchy when it's out on loan. :rofl2:
x 3565
Yep, the cut-outs clear the fuel pipes to give a better fit over the 'nut' on the top of the filter, and yep - it's 27mm.
From what I understand though, this isn't a universal socket for all diesel filters !! It'll only fit the ones that it is designed to fit :)
x 1955
I haven't needed a socket for the oil filter until now as both the Xsara and 2003 C5 have canister type filters. TBH I can't remember (and cba to go outside and look!) whether either of those cars have the opportunity for a socket on the fuel filter as I've been able to remove the top using my hands. Still, best to be prepared.
x 8457
myglaren wrote: And oil filters :)
Yes, great for that too, especially on an Activa :wink:
x 8457
I was reminded today just how useful a tool I once bought 'on-spec' is...
A variable length breaker bar... Just the ticket for undoing tight T55 Torx brake caliper bolts... You can adjust it to get maximum length within the confines of the wing...
x 1955
Well, not exactly a waste of money but paying out before it's absolutely necessary.
The Xsara fuel filter has a plastic hexagon on top but it's considerably smaller than 27mm. The 2003 C5 has no hexagon and the 2013 C5 X7 seems to have no fuel filter that I can see! The oil filter on the X7 has a hex on the top and may be 27mm but there's so much stuff on top that there's no room for a ratchet or extension to go in.
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
C5 x7 163 has a tricky plastic oil filter with a 27.. not much room paul as you say..
osx
(Donor 2022)
x 15
Unread post by osx »
this is probably the best tool. just need to make sure it is compatible with x7
C5 X7 Exclusive 2.0 HDi Auto
x 3565
Here's the socket fitted to my fuel filter top from about 5 minutes ago :)
The top of the housing is marked as Purflux FC582
osx
(Donor 2022)
x 15
Done it this morning with the special socket. Did think of sucking some diesel out first to make it tidier next time - can you use that small valve just left to the socket?
dnsey
x 19
Unread post by dnsey »
I open the water drain valve, so the fuel drains into a container as soon as air can enter the housing.
osx
(Donor 2022)
x 15
I think you can open the water drain valve at any time and possibly? pump the water out?
dnsey
x 19
Yes, you can pump the water out, but only by pumping fuel in.
