Tool to remove oil/fuel filter
osx
(Donor 2022)
x 15
Unread post by osx »
What is the recommended tool to remove the fuel/oil filter cap? Was going to try with a 27mm socket but don't want to damage the plastic as it seems to be a very tight seal.
C5 X7 Exclusive 2.0 HDi Auto
x 1240
Re: Tool to remove oil/fuel filter
Unread post by Peter.N. »
My first question would be what sort of oil filter but I think the 27mm socket answers that. Providing that it is the correct size socket it should undo it OK. Make sure that it is pushed right on and apply rotational pressure slowly and it should come undone all right.
Sloppysod
x 386
Unread post by Sloppysod »
I agree with Peter, having just replaced mine using an adjustable wrench. I will be getting a 27mm flexible ratchet spanner next time, about £14 from Ebay.
Sent from my GT-I9195 using Tapatalk
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
osx
(Donor 2022)
x 15
Link to the flexible ratchet spanner?
x 5652
I have a set of these and they are very useful but I did see a set somewhere - possibly Halfords, that had ratcheting open enders - not flexible at that end though.
x 1987
Unread post by Stickyfinger »
I have had a hankering for a set of these
http://www.lasertools.co.uk/product/4891
BenC5HDi
Not Mike
x 45
Re: RE: Re: Tool to remove oil/fuel filter
Unread post by BenC5HDi »
Stickyfinger wrote:I have had a hankering for a set of these
Oh dear. I've come over all unnecessary after seeing those :O
Sent from my SM-N9005 using Tapatalk
osx
(Donor 2022)
x 15
No movement - worried that i might break something if i apply more force. Really strange. Do you guys remove the metal guard or leave it in place?
Estately
x 22
Unread post by Estately »
I agree it does feel as though something will break. After disconnecting the fuel lines, I use a half inch drive 27mm socket well located and with a short extension, if you don't have a breaker bar you can increase the legth of your ratchet with some one and three eighth plastic pipe (sink variety). As Peter says ensure that all the effort goes into rotation.
Gradually increase the effort until it slowly starts to turn, the rubber seal in the plastic housing is a very tight fit and you will notice the stops for re fitting as in my opinion there is no 'feel' as to what the final tightness should be. The metal bracket can be left in situe, use it to stuff some rags to soak up any fuel that spills as it comes apart.
Hope that helps.
If it can happen it will.
x 8302
Estately wrote:Hi,
Hope that helps.
Yes it does :D An excellently written procedure for this difficult task. Exactly the technique I use on them...
Always, if it's tight and needs gently applied force to move it then a log breaker bar is by far the best tool. It might seem counter-intuitive but it works every time because the force is a lot more controllable and therein lies the secret.
x 3566
If you're talking about having trouble removing the fuel filter, then some of the filters are best undone with a socket like this:
http://www.ebay.co.uk/itm/Laser-5270-Fu ... SwcldUapAa
Laser tools part 5270 - other manufacturers are available.......
x 8302
Laser really do some brilliant special tools :D
x 3566
CitroJim wrote:Laser really do some brilliant special tools :D
Indeed so. I normally buy the odd tool from their range every now and then working under the "it'll come in useful one day" mantra :-D
x 8302
bobins wrote: working under the "it'll come in useful one day" mantra :-D
I do that with loads and loads of tools and invariably they do, even if not strictly for their intended purpose...
An example being oil filter pliers being great for the final removal of spheres...
x 5652
And oil filters :)
More so the retaining ring on the C5 fuel filter.
