Glow Plugs Annihilate 2.0HDi Xsara Picasso
- x 2941
Re: Glow Plugs Annihilate 2.0HDi Xsara Picasso
Ps. that picker upper you show can be had with a magnet end.
- x 7164
If you retain any affection for the "8" from your piston pulling out days you will probably enjoy this. Its an Austin 8 proving its robustness in the Lake District. How many modern cars would stand up to this trial?Gibbo2286 wrote: Now when I were a ladI used to take pistons out the bottom way on old Ford 8s and Morris 8s, re ring them and put them back, it was common practice....
- x 2941
A nice little film, I wonder if the same trip could still be made.
A hundred miles in six hours though............
- x 7164
Maybe i have underestimated my diy mechanic skills. I have just completed a haynes 5 spanner job in half an hour!
...the injector on cylinder no. 4 is out...
The hole is dissapointingly sma?l though
- x 7164
The Injector
Is there a "sealing washer" left behind in the bore for the injector?
Probably would be the answer.....if so what is the easiest way to get it out......douse in plus gas..then what?
Any assistance greatfully received
jgra1
- (Donor 2021)
- x 37
ahh Neil that isn't a large nozzle
- x 7164
Yes, not quite the size of hole I was hoping for to do a bit of fishing with a magnet!
The injector diagram
Item 9 described as engine injector protector I haven't discovered, and another slight difference with the digram is that all injector clamps are secured with bolts rether than studs and nuts.
The little sealing ring is definitely still in the injector bore.
jgra1
- (Donor 2021)
- x 37
I think you can dislodge the sealing ring without much effort.I don't think it's magnetic though..
OnlinePaul-R
- x 1940
Sealing rings are usually (certainly used to be) copper. There is a tool available for removing stuck washers which basically fits into the centre, expands and then you can pull the washer out. You might be able to get a similar effect with large coarse screw or possible jamming a large flat screwdriver in.
- x 7164
Thanks for the tips Paul
- x 7164
Here is a tool for the job for removing injector seals left behind in the injector bores in a cylinder head. At £26 its a bit pricy for a one off job, the coarse-threaded bolt as suggested by Paul may be worth a try.
The Sealy VS2054
The Sealy VS2054
- x 7164
Haven't quite been able to condemn the Picasso to the scrap heap just yet. Its just so much better than the ones I have been looking at recently. So every so often I pop the bonnet up and have a poke around.
Today's poke was a 10 minute success story.....got the sealing washer out of the injector bore! Doused it with plus gas round the edges and gently tried a range of my "special tools". I read on another thread, think it was CitroenXM , but may be mistaken, who recommended an appropriate diameter cross-head screwdriver to bite into the sides of the washer and extract it. My cross head screwdrivers were too small. thought you may get the same effect from a flat head with tapered sides wedgeing into the sides....not this time.
Dug out a straight round steel rod which proved to be a reasonably tight fit diameter, poked it down and it did grip the sealing washer and out it came on the end.
The bore with the washer out is no bigger, I think any productive camera work is out. Might try some manual ejections to expel any garbage from cylinder number 4 hopefully through the injector/glow plug hole.
jgra1
- (Donor 2021)
- x 37
Wonder if you can modify a telescopic magnet Neil.. so it would fit?
- x 7164
Never looked at telescopic magnets until 1 minute ago. Reasonably astonished that this one apparently extends to 660mm, can lift 1kg, and costs £3.40!jgra1 wrote:Wonder if you can modify a telescopic magnet Neil.. so it would fit?
telescopic magnet
jgra1
- (Donor 2021)
- x 37
Yep that sort of thing
I have at least 3! 2 have a torch in the end ..very handy.. one doesn't and that's the one I would grind down..
