V6 Auto box oil
fatherjack2002
- x 5
V6 Auto box oil
Hi folks, what is the type, or code for the oil in the V6 autobox ? I ask this question as there is a local ( oil and gas) supplier who may be able supply at a lot less than the main dealer, or GSF.
Also i've been told it's recommended do a second oil change about 1k after, as the torque converter will still have the original oil in it.
Does this sound about right ?
Cheers Paul
Cheers Paul
1995 Xantia VSX 1.9 TD, RIP
N*ssan Pr*mera . HATING EVERY MILE
1994 Xantia LX 1.9TD, RIP
1997 Xantia desire 2 re-homed
2002 Pugeot 307 HDI (not quite a Xantia, but still French)
- x 8340
Re: V6 Auto box oil
Hi Paul,
Only use genuine Esso/Mobil LT71141 and ABSOLUTELY NOTHING ELSE
This topic has been covered in great detail in the past on here and a quick search will reveal..
Don't you dare use anything else or anything that claims to be compatible. It isn't. End of..
LT71141 is light straw in colour and smells like rancid cat's pee.
Those ATFs that claim to be compatible are based on DEXRON and they definitely are not!
Yes, as the Torque Converter traps around 4 litres of ATF not all of it can be changed in one go so a second change is recommended soon after.
- x 1997
Re: V6 Auto box oil
are you trying to make some kind of point there Jim ?
- x 8340
Re: V6 Auto box oil
Me? Now whatever gave you that impression Alasdair?Stickyfinger wrote:are you trying to make some kind of point there Jim ?
Can't think why you could possibly think that
momag46
- x 78
Re: V6 Auto box oil
"SMELL LIKE RANCID CAT'S PEE" - Now I know what you were doing under Alasdair's car yesterday - checking its smell!!!!
I'm now going out to find some old car pee to check out this smell.
Maurice
Maurice
1999 V6 Xantia
jgra1
- (Donor 2021)
- x 36
Re: V6 Auto box oil
If your car is peeing Maurice I think auto box oil is last of your worries
- x 8340
Re: V6 Auto box oil
Alasdair's is a manual Maurice, so its gearbox oil just stinks awfully of what manual gearbox oil stinks of. All I know is it makes me feel sick.. I was actually doing a bodge to get him home safely after his fuel lines became dislodged.momag46 wrote:"SMELL LIKE RANCID CAT'S PEE" - Now I know what you were doing under Alasdair's car yesterday - checking its smell!!!!
Maurice
Oddly, with LT71141, smell besides, it upsets my stomach when I work with it for any length of time, say when rebuilding a gearbox... The only oil I know that does. I've swallowed enough LHM over the years know that doesn't cause such a problem...
LHM is a rather excellent hair conditioner. It makes it very soft
jgra1 wrote:If your car is peeing Maurice I think auto box oil is last of your worries
momag46
- x 78
Re: V6 Auto box oil
The only thing my car is peeing is "£s" into the fuel tank and we all know what that smells /feels like
I've now go two photos of Jim under the side of a Xantia, one from yesterday and the other from the 2013 CXM rally - I think it could be getting a regular thing Jim
Maurice
Maurice
1999 V6 Xantia
- x 8340
Re: V6 Auto box oil
It's my natural position in life Mauricemomag46 wrote: I've now go two photos of Jim under the side of a Xantia, one from yesterday and the other from the 2013 CXM rally - I think it could be getting a regular thing Jim.
Never happier than when I'm lying under an old Citroen
momag46
- x 78
Re: V6 Auto box oil
I tried lying under old women for a while but I had to stop when the wife found out.
Just noticed, what's the 0xHeart at the bottom right of each post?
Maurice
Maurice
1999 V6 Xantia
- x 1937
Re: V6 Auto box oil
It's the number of times that particular post has been "liked" by another member.
Just to show I've liked your last post.
momag46
- x 78
Re: V6 Auto box oil
Thanks for that - hadn't noticed it before.
Maurice
Maurice
1999 V6 Xantia
superloopy
- x 19
Re: V6 Auto box oil
Wouldn't have thought that would bother the wife .... now young women, maybemomag46 wrote:I tried lying under old women for a while but I had to stop when the wife found out.
Maurice
Mike
fatherjack2002
- x 5
Re: V6 Auto box oil
Hi, going back to the oil change matter, this may sound a basic question, but once the oil is removed how much is refilled, as the torque converter will still be holding some amount of oil ? Also how many liters does the box hold ?
cheers Paul.
cheers Paul.
- x 1445
Re: V6 Auto box oil
You should measure the amount that came out, and start by putting the same amount of new oil in. Then you follow the method for checking the fluid level and arefully add moe until the level is correct. 1997 and 1998 transmissions have a dipstick, later transmissions don't and the level is checked via level plugs.
