Trailing arm bearings again..
Chriz1
Unread post by Chriz1 »
So my 206 needs new trailing arm bearings,
Passenger side has a lean on the wheel at top and is wearing the inside edge of the tyre although I can't find any play?
I rang a few garages local to me to get a price but none of them will change them only change complete axle
Why is this?
Looking at YouTube videos it looks straight forward,
Anyone here changed them are they as easy as straight forward as they look should I tackle the job or source a decent axle ?
Cheers
spider
x 77
Re: Trailing arm bearings again..
Unread post by spider »
Chriz1 wrote:So my 206 needs new trailing arm bearings,
Why is this?
Cheers
I think the 'problem' here is actually getting the thing apart rather than anything else. :)
From a personal point of view a good used axle would be my personal choice. Tip: If going this route budget for replacement brake parts if required as it would be best (ideal time) to renew them and / or swap the existing brakes from your old axle to the 'new' one.
Andy.
x 1238
Unread post by Peter.N. »
There was a firm in Honiton who would either send you a replacement or fit it for the same price but I see thee have moved nearer to me now in Axminster:
http://abaxles.co.uk/en/about/
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
They arent anything like Citroens rear arm brearings to change as they have torsion beam springs in the tube too...
A very sad...
1994 XM 2.1 d auto
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
Peter.N. wrote:There was a firm in Honiton who would either send you a replacement or fit it for the same price but I see thee have moved nearer to me now in Axminster:
I drove my daughters Xsara down to them in 2012 and they replaced the axle in about 2 hours - all for a reasonable price. The old guy who ran it was hands-on but I guess he may have retired now. Surely the new place will be easier to find than Mountjoys!!!!
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
Oldpug
x 93
Unread post by Oldpug »
Mountjoy engineering became SSP engineering and later became AB Axles.Over the years I`ve used all three without any problems.Recon` axle delivered to your door ready to fit,then the old unit collected.A clever DIY man with good tools should be able to swop it all over in 3-4hrs.
I gave up doing Peugeot rear arm bearings years ago,too much time and hassle.Everything will be seized up and difficult to take apart,get the ride height wrong and your in trouble.Also the main problem on 206`s is that when the bearings collapse the bearing surface on the tube gets damaged and it will need a whole new cross tube.
Chriz1
Thanks all for the reply, is it normal to have no play at all? I wiggle the wheel with the rear lifted and can't find any play. But there's a slight lean to the wheel causing tyre to wear uneven on inside edge
