Radio
This section is for General Enquiries or for Systems not Covered Above
KennyW
x 165
Radio
Unread post by KennyW »
Morning all,
On my C5 x7, are the 4 holes located on the radio console used to remove same.
Kenny
C3 1.4 petrol (SWMBO)
vborovic
Locked user account
x 40
Re: Radio
Unread post by vborovic »
Good for you ... :D
x 2006
Re: Radio
Unread post by Stickyfinger »
4 holes.....lucky
KennyW
x 165
Re: Radio
Thanks for the replies guys!!!!!!!!!!!!!!!!!!!!!
the reason I'm asking is, pure dab is listed but not receiving any listings. I was wanting to check for dab ariel socket.
Kenny
vborovic
Locked user account
x 40
Re: Radio
So, in simple english ... you want to pull the unit out? Why didn't you says so ... you need something like this:
Or 4 thin screwdrivers, to insert into the holes to release the side hooks
x 2006
Re: Radio
like nearly every other radio since DIN then .............
KennyW
x 165
Re: Radio
Thanks for the reply as I suspected wire coat hanger job. Got some I made earlier (Blue Peter).
Kenny
x 2006
Re: Radio
LOL....you can make a Tracy Island with it later :)
jgra1
(Donor 2021)
x 36
Re: Radio
Unread post by jgra1 »
Hi Kenny.. you have a dab unit in your x7? Tell me more ;) I spend a lot of time on 5 Live 5 sport extra and radio 6 ;)
x 6950
Re: Radio
jgra1 wrote:Hi Kenny.. you have a dab unit in your x7? Tell me more ;) I spend a lot of time on 5 Live 5 sport extra and radio 6 ;)
I don't believe any of the C5s have DAB radios - even the emyway fitted to the 2015 C5 doesn't. They are available as an Ezi-DAB and AutoDAB link below, but not available for Navidrive 3D owners. They have also been known to cause interference or be unable to get a signal at all - so some people have returned them. The newer emyway systems as fitted to some later DS5 models do have DAB integrated, but is likely to be more common on newer vehicles I would expect.
http://www.citroen.co.uk/owner-services ... /dab-offer
@ Kenny - The scrolling live text display on the FM Radio stations could give the mistaken impression it is a DAB radio, when it is just the radio text information that is transmitted as part of the RDS system by radio stations. Do you have a separate Ezi-DAB or AUTODAB system that has been added?
The AUTO DAB works with the exiting head unit and displays the stations and info via your car's exisitng display / headunit. The actual aerial and the DAB unit is hidden away under the dash somewhere, with the unit controlled via steering wheel controls. The EZI-DAB is a separate DAB unit with it's own controls and display that sends the audio directly through the car's existing audio system. If you have one of these units (which are recommended to have a separate DAB aerial installed), there won't be a separate DAB aerial at the back of your existing head unit - it will be wired into either of the DAB units and then connected to the windscreen or somewhere else - here's a link to an AUTODAB kit so you can see what is installed as part of it:
http://www.autodab.com/aftermarket/Prod ... wqfjLUrI-U
Here's the AUTODAB:
http://www.accessories.citroen.co.uk/na ... -kit-1705/
Here's the EZI-DAB
http://www.accessories.citroen.co.uk/na ... -kit-1706/
