You'll often find the leak is not in the matrix itself but failed O rings between the matrix proper and the extension bit with the elbow sockets on it... The matrix is common across many PSA vehicles but the extension bit varies, hence it's bolted on and sealed with O rings. Technically, just a change of those rings should fix it but none of us have been brave enough to put it to the test yet...
Xantia heater matrix - quick fix with forte or replace?
- x 8422
Re: Xantia heater matrix - quick fix with forte or replace?
Good work Stu
well done!
chinkostu
- x 30
Its cumbersome, get a helper to hold one side and ease it out gently, mine got caught twice, once on the fusebox and the second time was a connector clipped to the dash.xantiamanic wrote:Lifting the dash ... easy? And ... what was the foam for? I dont think my matrix has any in the box. I've got a spare set of heater pipes in case they break.
Sent from my LG-D855 using Tapatalk
No idea on the foam, i put mine widthways in the gap between the plastic join and the fins, so the new matrix is pretty well sealed!
CitroJim wrote:Good work Stuwell done!
Thats what I think, might need pressure to show up any leaks. But to get to that join to change the o rings its the same amount of work as to put a new matrix in!
Set for sunday now as i've got work between now and then, so now its plumbed we should hopefully have it sorted!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
- x 8422
When I've pulled the joint apart on duff matrixes Stu, the O rings have been found to be rock-hard...
chinkostu
- x 30
These ones probably are too!CitroJim wrote:When I've pulled the joint apart on duff matrixes Stu, the O rings have been found to be rock-hard...
I've also forgotten where half of the bolts go...
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
- x 5674
^ job's not done unless you have a few bits left over.
- x 1997
I find pre-marking bolt/screw holes with Tippex helps.....you can spot them easy with a torch in those dark area
superloopy
- x 19
That's one to rememberStickyfinger wrote:I find pre-marking bolt/screw holes with Tippex helps.....you can spot them easy with a torch in those dark area
Mike
- x 8422
A lot of small pots and lots of practice works for me!
BenC5HDi
- Not Mike
- x 45
Re: RE: Re: Xantia heater matrix - quick fix with forte or replace?
+1 for this, I do this too when working in dark places.Stickyfinger wrote:I find pre-marking bolt/screw holes with Tippex helps.....you can spot them easy with a torch in those dark area
Sent from my SM-N9005 using Tapatalk
chinkostu
- x 30
I just went straight to hard mode and shoved them all in one tubCitroJim wrote:A lot of small pots and lots of practice works for me!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
- x 1997
Boxes/Packets of biscuits (cheep ones) yield many a tray for small bits..............
- x 8422
Egg trays too...
And take-away food containers. After washing them of course..
chinkostu
- x 30
Nah leave curry on the bolts for that authentic "s**t it didn't work" smellCitroJim wrote:Egg trays too...
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
- x 1997
Covers up the smell of anti freeze from the leaking heater matrix ........
I hope that the years blowing cold air (southern French car) has preserved my O rings
- x 1941
I have, on my daughter's Pug 206.CitroJim wrote:Technically, just a change of those rings should fix it but none of us have been brave enough to put it to the test yet...
I got a SH matrix from a scrappy and then, when I took the old one out, found that not had the O rings gone a bit squashed but also the stupid spring clips were missing, only one screw and nut per tube. So, some extra (5mm?) screws and nuts with new O-rings later it was all systems go.
I was very lucky being able to return the matrix to the scrappy and get a refund, especially as it was in no way their fault.
