Xantia heater matrix - quick fix with forte or replace?
x 8427
Re: Xantia heater matrix - quick fix with forte or replace?
Good work Stu :D well done!
You'll often find the leak is not in the matrix itself but failed O rings between the matrix proper and the extension bit with the elbow sockets on it... The matrix is common across many PSA vehicles but the extension bit varies, hence it's bolted on and sealed with O rings. Technically, just a change of those rings should fix it but none of us have been brave enough to put it to the test yet...
chinkostu
x 30
Unread post by chinkostu »
xantiamanic wrote:Lifting the dash ... easy? And ... what was the foam for? I dont think my matrix has any in the box. I've got a spare set of heater pipes in case they break.
Sent from my LG-D855 using Tapatalk
Its cumbersome, get a helper to hold one side and ease it out gently, mine got caught twice, once on the fusebox and the second time was a connector clipped to the dash.
No idea on the foam, i put mine widthways in the gap between the plastic join and the fins, so the new matrix is pretty well sealed!
CitroJim wrote:Good work Stu :D well done!
Thats what I think, might need pressure to show up any leaks. But to get to that join to change the o rings its the same amount of work as to put a new matrix in!
Set for sunday now as i've got work between now and then, so now its plumbed we should hopefully have it sorted!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
x 8427
When I've pulled the joint apart on duff matrixes Stu, the O rings have been found to be rock-hard...
chinkostu
x 30
CitroJim wrote:When I've pulled the joint apart on duff matrixes Stu, the O rings have been found to be rock-hard...
These ones probably are too!
I've also forgotten where half of the bolts go...
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
x 5677
^ job's not done unless you have a few bits left over.
x 2004
Unread post by Stickyfinger »
I find pre-marking bolt/screw holes with Tippex helps.....you can spot them easy with a torch in those dark area
superloopy
x 19
Unread post by superloopy »
Stickyfinger wrote:I find pre-marking bolt/screw holes with Tippex helps.....you can spot them easy with a torch in those dark area
That's one to remember :wink:
Mike
x 8427
A lot of small pots and lots of practice works for me!
BenC5HDi
Not Mike
x 45
Re: RE: Re: Xantia heater matrix - quick fix with forte or replace?
Unread post by BenC5HDi »
+1 for this, I do this too when working in dark places.
Sent from my SM-N9005 using Tapatalk
chinkostu
x 30
CitroJim wrote:A lot of small pots and lots of practice works for me!
I just went straight to hard mode and shoved them all in one tub :shock:
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
x 2004
Boxes/Packets of biscuits (cheep ones) yield many a tray for small bits..............
x 8427
Egg trays too...
And take-away food containers. After washing them of course..
chinkostu
x 30
CitroJim wrote:Egg trays too...
Nah leave curry on the bolts for that authentic "s**t it didn't work" smell ;)
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
x 2004
Covers up the smell of anti freeze from the leaking heater matrix ........
I hope that the years blowing cold air (southern French car) has preserved my O rings :)
x 1944
CitroJim wrote:Technically, just a change of those rings should fix it but none of us have been brave enough to put it to the test yet...
I have, on my daughter's Pug 206.
I got a SH matrix from a scrappy and then, when I took the old one out, found that not had the O rings gone a bit squashed but also the stupid spring clips were missing, only one screw and nut per tube. So, some extra (5mm?) screws and nuts with new O-rings later it was all systems go.
I was very lucky being able to return the matrix to the scrappy and get a refund, especially as it was in no way their fault.
