Hi, I have here my cx 1984 GTI turbo and last few days it won't start anymore. It has run fine last few days.
Ignition modules checked
Fuel checked
Injectors ??
Crankshaft sensor?
ecu ok
cx won't start
jsp
- x 12
cx won't start
My Citroens update:
http://www.frenchcarforum.co.uk/forum/v ... 14&t=50070
aerodynamica
- x 216
Re: cx won't start
Crankshaft sensor is the most notorious cause, I can't recall if there is one sensor or two for an '84 Turbo 1. If it is missfiring it might be one of the two coil trigger wires from the ECU -I'd check and clean those first. My go-to guy for this stuff in the past was a chap called Fil Van Delft based near Birmingham but not sure he's on here any more? Another thing to check is the 'big blue' relay for the fuel pump. I've also heard stories of CX ignition switch failing - sometimes aggravated by having too many keys pulling on the key ring. Is the ECU getting power?
Graeme M
jsp
- x 12
Re: cx won't start
are these still fs or nfp??
yes ecu getting power.
My Citroens update:
jsp
- x 12
Re: cx won't start
still not starting.........
My Citroens update:
Deanxm
- x 87
Re: cx won't start
Have you checked for fuel pressure at the rail and a spark? kind of need to know which one is absent to have a clue but if there is no engine management light while cranking and one day it worked and the next it did not then i would be looking at the crank sensor as suggested above as a starter.
I take it these are mechanical ignition with EFI? if it is the failed crank sensor would likely stop fueling and you will have a spark.
D
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
jsp
- x 12
Re: cx won't start
are these crank sensors still available?
My Citroens update:
Deanxm
- x 87
Re: cx won't start
XM Prestige PRV6 92
jsp
- x 12
Re: cx won't start
That is the wrong plug for this car. I have a square plug.
My Citroens update:
Deanxm
- x 87
Re: cx won't start
what you have a length of cable coming from the sensor with a three pin rectangular plug or a square plug striaght onto the srnsor?
It will still be available, you will probably find it was fitted to a whole raft of Citroens of the time, the one i linked may be a generic photo too so its worth checking.
D
D
XM Prestige PRV6 92
jsp
- x 12
Re: cx won't start
two pin rectangular plug
My Citroens update:
CGATCX25GTITURBO
- x 16
Re: cx won't start
I have a brand new sensorjsp wrote:two pin rectangular plug
If your'e still looking for one you can send me a PM.
Neil aka CGAT
1986 CX25 GTI TURBO 1 SERIES 2 'CGAT'
1998 XANTIA 19TD ESTATE
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
1989 CX GTI Turbo 62k miles in a barn since 2001, project started 2023.
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
jsp
- x 12
Re: cx won't start
yes still wont start I took off my other cx the crankshaftssensor and still nothing........
Its getting spark and fuel.
My Citroens update:
CGATCX25GTITURBO
- x 16
Re: cx won't start
okay, has the inlet hose come off the turbo? the rubber elbow is what I'm tallking about. It is possible air isn't being drawn past the air flow meter and the fuel will be cut off. could just be fould psark plugs not sparking under compression.
Neil aka CGAT
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
jsp
- x 12
Re: cx won't start
still nothing. All hoses ok.crankshaft sensor working. ECU?
My Citroens update:
jsp
- x 12
Re: cx won't start
Still nothing ahhh h someone help me?
My Citroens update:
