Xantos and Xantia madness
xantos
x 10
Re: Xantos and Xantia madness
Unread post by xantos »
And here is my TCT Activa project. Sadly the engine caught fire... I believe that the petrol pipe split and gasoline poured over the hot engine. Before the fire it was really looked after and quite a few thousand euros was spent on it. New strut tops (original Citroen), hydractive valves, spheres, engine mounts, brakes, rear arm bearings, tyres (winter and summer) etc. I have the donor apart so now just need to fit everything needed. But it's hard to find time as it's quite a project...
Xantia Break 1.9TD (jammed b****!)
Xantia Activa 2.0 TCT + LPG (1998) (peeing b****!) RIP
Xantia Activa 2.0 TCT (1998) (burnt b****!)
Xantia Activa 3.0 V6 (1998) (not a b****! yet :-D )
C4 Exclusive 2.0 HDi (gear shifting b****!)
harryp
(Donor 2022)
x 73
Unread post by harryp »
Xantos, that is heart-breaking :cry: . Do hope it has't done too much damage, esp to wiring and such. Your project just ramped up. So sad.
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
xantos
x 10
I bought this car so the previous owner cared for it. Bought it because it is generally in really good condition.
My TCT had real rust problem but the engine was rebulit, so it became a donor car...
x 8418
xantos wrote: With a bit help of angle grinder and MIG welder it can be done!
As can most things :lol:
xantos
x 10
I'm thinking of swapping the interiors of my TCT and V6 as the TCT has leather in really good condition and V6 has cloth and it's also in good condition. I will probably sell TCT and I will be lucky if I get a few hundred euros for it. What do you think about interior swap?
Anyone here wants to buy a burnt TCT Activa? 8-[ I add all the bits and pieces and also the engine that was rebuilt aprox. 15kkm ago...
x 8418
I'm so sorry to see the car was on fire :(
It's a known problem now with the TCT and always worth checking the fuel lines to the fuel rails very regularly... They perish badly...
xantos
x 10
The four bi***** of apocalypse :twisted:
x 8418
:D
xantos
x 10
Did a bit of spannering...
Changed the track end rods, lower ball-joints, stabiliser rods, changed oil, oil filter and fitted a new steering gaiter. Stabiliser rods lasted 6 months and started rattling. I don't remember which brand I used but now I have TRW and hope they will last longer... Well its no surprise they didn't last long considering sh**** roads we have :evil:
Then went to a garage to adjust the track rods. The car feels much sharper on curves and there is no more rattling from the suspension :-D And ride quality has improved also 8-)
xantos
x 10
Would it be ok driving with no coolant (cold engine) for max. 2 minutes?
I am changing the cambelt on my Xantia V6 and I planed to change the radiator as well as it is leaking but I didn't get the right one :evil: Just checked the box and not its content and today shock! Right ident number but wrong contet!
So I wonder if I can drive of the ramp and park it outside the workshop with no coolant whatsoever in the engine. I would very like to avoid pushing the car... :roll:
BenC5HDi
Not Mike
x 45
Unread post by BenC5HDi »
No. Push it out.
Sent from my SM-N9005 using Tapatalk
x 8418
BenC5HDi wrote:No. Push it out.
Very wise advice...
V6 head gaskets can go very quickly indeed with no coolant present. Just not worth the risk.
xantos
x 10
Forgot to mention that coolant is driping somewhere above the gearbox (cabin side). Is there a standard fault on V6?
x 8418
xantos wrote:Forgot to mention that coolant is driping somewhere above the gearbox (cabin side). Is there a standard fault on V6?
Yes, the 'degassing tank' or 'bubble breaker' most likely.. That's the white spherical plastic object just below the coolant header tank which in itself is a problem as it splits..
Also, in that area is a short pipe between the thermostat housing and the 'degassing tank' that likes to split too...
The 'degassing tank' is now NFP sadly :( The header tank is still available...
xantos
x 10
Well than the bubble breaker has to be repaired... I'm thinking of taking it to someone who welds plastics. And my radiator as well...
Cam belt changed and it's not a difficult at all job as someone might expect! :-D Just couldn't get the belt on while everything was attached, so I removed the whole tensioner assembly and positioned the belt and than bolted the tensioner assembly. It's one thing that puzzles me... Why are the cam shaft pulley bolts torqued with only 10Nm? I would expect that it would be more... Would there be a problem if the would be tightened FT (full torque of fu**** tight :) )
EDIT: It's quite difficult to get to the bubble breaker as I was looking... Inlet manifold off I would reckon...
