Cost for replacing outer CV gaiter
osx
- x 15
Think it is time to get it replaced before next MOT and before it causes any problems. Any idea of the total cost (part and labour)?
C5 X7 Exclusive 2.0 HDi Auto
jsp
- x 12
Re: Cost for replacing outer CV gaiter
Just the boot?
I guess 35 quid each each side. This is what my workshop charges my customers.
Any mechanic could replace this within 1hour if it is not a hardened boot.
My Citroens update:
http://www.frenchcarforum.co.uk/forum/v ... 14&t=50070
osx
- x 15
That's quite reasonable. Had the other side replaced a year ago when i changed the steering rack and asked them to do both but was told there was not need - that will teach me!
- x 1504
By the looks of it there are 2 types of shaft - one you can do on the car, the other needs to come off and the inner joint taken apart. But I suppose you could do even the type that should be done from the back with a stretchy boot. Quite difficult to get the shaft out of the hub on an X7 - I very much doubt you will get it for £35, twice that perhaps...or 4 times at the dealer!
jsp
- x 12
If some driveshafts are cheaper than refitting a boot just replace the whole driveshaft.
My Citroens update:
osx
- x 15
Driveshafts go for £150+ so not going to replace it.
Richard - how do you know which type? Is it different for Auto or Manual?
- x 1504
It looks like they are used interchangeably - you will need to have a look at the shaft and find the label on it. GKN cannot be done by removing the outer joint, whereas PSA and NTN types can. Like I say though, you could do either with a stretchy boot.
jsp
- x 12
+1 on the stretch boot easiest way.
My Citroens update:
daviemck2006
- x 485
I did mine with a split boot that glued together no problem. No need to undo driveshaft at all!
Sent from my SM-G361F using Tapatalk
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
osx
- x 15
Too many options!
I think the consensus about split boots is that they don't last very long and it can be a messy job.
What sort of stretchy boot is compatible with the X7?
Is there a part number/link for the PSA and NTN types?
jsp
- x 12
Universal type.
My Citroens update:
lexi
- x 133
Stretch boots are awkward to do on the car with that mad cone. Slippy things. Even the makers say to pull drive shaft onto the bench. If doing so get a new driveshaft seal into gearbox and some oil to top up.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
jsp
- x 12
You might consider getting this and do it by your self.
My Citroens update:
- x 1955
Flipping heck! Something from Anne Summers?
- x 5688
