Intermittent beeping when indicating right.
djjakey123
New User
Unread post by djjakey123 »
Hi all, my Nan has a 2008 reg xsara Picasso. When indicating right, there is a constant beeping coming from the steering column. This also happens when the headlights are turned off.
Any ideas or advice will be greatly appreciated..
Thanks, Jake.
Bick
x 43
Re: Intermittent beeping when indicating right.
Unread post by Bick »
I would suspect a comms unit fault but i may be wrong? suspect someone will be along to correct me if i am?
x 6950
Yes, very likely a Comms 2000 fault. Depending upon model, it can also affect wipers and lights coming on and off on their own (if you have the auto lights) etc. Some of these Comms units can be sent off for repair, or the whole module can be replaced. If you need help with identifying the correct part number, send a private message with the vehicles VIN number.
djjakey123
New User
Brilliant, thanks so much for the advice. I will have a look about for one or see about repairs. It's probably that because like you say, the windscreen wipers have a mind of their own. Haha, tar.
x 6950
Just remember there are loads of different models and revisions of these units - you have to get the right one according to your vehicle and the options fitted - hence the offer to look up the correct part for you to aid in your search. Repairs can't always be made - again depends on the unit as there were at least 3 manufacturers of the units and the internal electronics were wildly different.
BenC5HDi
Not Mike
x 45
Unread post by BenC5HDi »
As per my post on the other thread, Graeme Hall is the man to contact to find out if it's repairable..
Sent from my SM-N9005 using Tapatalk
