Wanted: Front Activa Anti Roll Ram
DS21
Unread post by DS21 »
Hi Guys,
My Series 1 Activa passed it's MOT but did have an advisory that there is a slight leak on the front anti roll bar (ram). They also said that the rear one is leaking too but my Citroen garage told me that it's the front that is worse.
Can anyone advice where I go from here, can they be repaired, does anyone have a known good one for sale?
xantos
x 10
Re: Wanted: Front Activa Anti Roll Ram
Unread post by xantos »
Xantia Break 1.9TD (jammed b****!)
Xantia Activa 2.0 TCT + LPG (1998) (peeing b****!) RIP
Xantia Activa 2.0 TCT (1998) (burnt b****!)
Xantia Activa 3.0 V6 (1998) (not a b****! yet :-D )
C4 Exclusive 2.0 HDi (gear shifting b****!)
DS21
Thanks for the link, my Citroen garage have already performed this modification but it doesn't seem to have done the trick in my case.
x 2007
Unread post by Stickyfinger »
Ye they can be repaired....(Most) often it is the leak back seals that are the problem.
Jim .....over to you (Jims links) http://www.eastment.net/ramrep/index.htm
the start of my story http://www.frenchcarforum.co.uk/forum/v ... &start=255
The tool I made for the removal of the scraper....you can borrow this if you need to....easy to make with the correct size washers and threaded rod however
http://www.mediafire.com/convkey/8a48/c ... sibfzg.jpg
EDIT: Just read your reply
x 8441
DS21 wrote:Thanks for the link, my Citroen garage have already performed this modification but it doesn't seem to have done the trick in my case.
There's a trick with the front as the XM repair gaiter is a little large and needs to be packed out to ensure a good seal at the top. Also, the lathe work to make a clean sealing surface is vital to the success of this repair.
DS21
Cheers all for the advice....
x 8441
I've sent you a PM George ;)
