Xantia Turbo Diesel autobox issues
DDB
Unread post by DDB »
Hi guys,
It's probably done to death here, but I'm looking for a bit of advice.
I recently acquired a 1998 (S) Xantia Turbo D Exclusive estate automatic, which has (I've been told) the Siemens AL4 box. When I got the car, I was aware of gearbox issues with it, which i'm trying to sort out now. When driving along it seems to be jumping gears a lot, and is a bit jerky.
I've just ordered 5 litres of Mobil LT71141 ATF to give the box a fluid change. I'll also plug it in to the Lexia to see what comes up. Is there anything else I need to look out for?
Thanks in advance guys.
Dave
Milton Keynes
Dave
'98 Xantia V6 Estate Exclusive Auto
'82 CX Athena
'86 Visa 652cc
And lots of other non-French stuff
x 1463
Re: Xantia Turbo Diesel autobox issues
Unread post by xantia_v6 »
There is quite a lot of info already on this site. Assuming that you are using a full sze screen (not a phone), then you will see a google search box on the right hand side of this page, just below the header. Type "al4 solenoid" (without the quote marks) into that pox and read a few of the returned links, and you should see what you are likely to be in for (it is fixable).
x 3296
If the oil that comes out is black (and you are prepared for the expense) get another 15L of oil. Because of the torque convertor, it is not possible (unless you strip the gearbox) to get much more than half the oil out. Assuming no other problems, what you need to do is to get as much oil out as you can (when the gearbox is at a certain temperature, but I DON'T know what that is), then top it back up (measure how much came out, replace with the same amount), and then repeat every few hundred miles. I would suggest you post up the mileage of the car. The gearbox may be close to its' 'expiry' date (around 150,000 miles), and if it fails it can be expensive to sort. However, if it is still running, it is possible (by use of a reconditioned torque convertor and a few other things) to get another 150,000 miles out of it.
EDIT; If I have got this wrong I apologise. I am going by memory (from what I have read on this forum, not having had an automatic car), and I know that some gearboxes can cause you grief.
x 8414
Dave, the AL4 is well known for having electrovalve issues... They're apparently very easy to replace and as Mike says above, there's a lot of threads on here about it...
I have the official procedure for changing the ATF in an AL4. PM me your email address and I can send it to you as a PDF...
A Lexia is required to change the fluid to both see that it's at the right temperature for level checking and to reset the worn oil counter
Also, I appear to be local to you (Newport Pagnell) so if you need any support in doing the job, give me a shout...
DDB
sent you a pm, Jim
Dave
'82 CX Athena
'86 Visa 652cc
x 8414
DDB wrote:sent you a pm, Jim
Not seen it yet Dave :?
DDB
Not sure why it didn't go through... Just tried again :)
Dave
'82 CX Athena
'86 Visa 652cc
x 8414
It worked that time Dave!
