Diesel additive minimum level
Dcourt
Re: Diesel additive minimum level
Unread post by Dcourt »
they think it could be the pump that is not pumping the additive to the fuel
x 3296
I would (before doing any more 'repairs') suggest getting a Lexia onto you car. That way it could reset the counter, and also look for any faults. Here is the link to Lexia owners;
http://www.frenchcarforum.co.uk/forum/v ... 19&t=29178
x 1994
Unread post by Stickyfinger »
Hell Razor5543 wrote:I would (before doing any more 'repairs') suggest getting a Lexia onto you car. That way it could reset the counter, and also look for any faults. Here is the link to Lexia owners;
This, 100%.......the only way to do it.
Dcourt
Would a Peugeot garage be able to do it then?
x 3296
They should, but I could not say at what price.
x 1994
1 hour charge and a Lexia charge £80 maybe ?
Hunt down a member with a Lexia and let them have a beer or two >?
Dcourt
I have messaged 2 members close to me before and they have never got back! That is assuming they got my message
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
Where are you dc
Dcourt
Henstridge Somerset.
Has anyone had there dpf removed? And is it a route worth going down or not?
x 1994
You are about 25 miles from me then !......pop up tomorrow ? (It will be chucking it down however but you only need to sit in the car with the laptop).....I am not very skilled but if you can get instructions from here first you are welcome to plug my kit into the car and try.
DPF removal is a MoT fail and will throw faults with out modifications and a remap
Dcourt
Where abouts you too bud?
And done anyone know any instructions for this because I have never done it before?
Cheers for your help
x 1994
Betwix Frome and Shepton.
As an alternative....give Phil Hunt a ring, he is closer and will help you out (a FANTASTIC Indi French car garage)
Phil Hunt, Motor Engineer, Specialises in Citroen. 01258 820270,
White Post Garage, Todber, Marnhull, Nr. Sturminster Newton, (North) Dorset.
Dcourt
Do you know if he is open on Saturdays?
x 1994
I would think his phone is....he HAS got a Lexia etc
