Xantos and Xantia madness
xantos
x 10
Re: Xantos and Xantia madness
Unread post by xantos »
Noticed today that my temperature is rising too much. I have a 3km hill to climb to get home and about 500metres is quite steep (2nd or 3rd gear). The temp got to just bellow 100°C so I stopped and checked if the fans are working. They did but I am certain that they were working just on 1st stage...
I read somewhere that it might be the relay on the fans "controlling" unit. Is that the most possible cause? A fuse perhaps? Just that I know where to start looking...
I tried to turn the AC on when I got home, but there was no response from the fans. The AC is out of gas that I know (because I didn't need to fill it after the engine rebuild as it was not so hot any more :-D ) but should the fans start nevertheless? Of course every test was made with the engine on... :wink:
I really need to get this sorted because I don't want to destroy the engine head just 10kkm after the engine rebuild. And I was really nice to the car when driving. Never over 3000rpm. Ok maybe once or twice when overtaking 8-)
Xantia Break 1.9TD (jammed b****!)
Xantia Activa 2.0 TCT + LPG (1998) (peeing b****!) RIP
Xantia Activa 2.0 TCT (1998) (burnt b****!)
Xantia Activa 3.0 V6 (1998) (not a b****! yet :-D )
C4 Exclusive 2.0 HDi (gear shifting b****!)
x 8264
Often this is because one fan has gone open-circuit Xantos.. In slow they run in series so if one is faulty the other one won't run...
Often it is brush issues and the fans can be provoked into working by poking them with a stick.
These are loads of posts on this forum covering fan issues!
x 1983
Unread post by Stickyfinger »
I have a little Dot of gloss white paint on each of mine....makes it easy to check operation later
(Truck Mech's have good ideas)
x 8264
Alasdair, if you bin your old TCT Activa, keep the fans and motors, they do fail regularly and are getting scarce.. I've seen off two on mine...
x 1983
I have the fans from the Green Goblin and the silver V6 as well Jim.....I can only keep so much sadly
xantos
x 10
CitroJim wrote:In slow they run in series so if one is faulty the other one won't run...
They both run in slow but neither fast. And both not running at all if AC on.
x 8264
Ahh, that's a bit different to the norm...
HansNOR
x 7
Unread post by HansNOR »
no worries sticky. when ur shed is full u start throwing it into bins and ship them to 'Norway. problem solved .
x 1983
You could have a whole bleeding car if you wanted but you have to come and get it :)
daviemck2006
x 496
Unread post by daviemck2006 »
If you weren't 600 miles from me I would be on my way down to you to fit a towbar onto the xantia with a dolly in the boot to take a car home lolol
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
x 1983
600 is not that far....:)
x 5634
It's the other 600, all uphill, back home that's the killer :)
x 1983
LOL
daviemck2006
x 496
Now you are tempting me lol.
Peugeot boxer 2016
In the family
x 1983
Coffee on offer and a fresh egg sarnie. You could even camp the night in the Hen House. I would put fresh straw in it for you and Beryl is pretty with yellow legs (which would be a talking point)
