Diesel additive minimum level
Dcourt
Hi I have just had a diesel additive minimum level message come up on my Peugeot 307 2.0 hdi 136, does anyone know how much pat fluid the tank holds and what pat fluid I will need to get?
Cheers
Cheers
- x 1983
Re: Diesel additive minimum level
If it has just come on, no rush......good few miles left before it runs out.
If you post your Vin number they will be able to advise
Dcourt
Ok thanks
Vin is VF3**************[VIN obfuscated, can be read by forum staff]
- x 1479
Similar thread on Citroen recently: http://www.frenchcarforum.co.uk/forum/v ... =3&t=50195
I had a look on servicebox but I couldn't find the additive mentioned anywhere. It gives the RP as 10089, which would suggest 176 as per the thread - assuming Pug is the same as Citroen!!
- x 1983
To be sure it is a dealer question/phone call I think.....
Dcourt
How long do you think the additive will last as the earliest I can get in into the garage is Thursday! The car is in daily use aswell?
- x 1983
ken newbold
- x 4
It might not even be low, just the computors think it is.
1998 1.9td Peugeot 806 (Red shed 2)
2004 Citroen C3 1.4HDi
2003 2.2 Pug 807, Gone and never again!
- x 3294
IIRC the computer does not 'know' how much additive there is (no level sensor), it merely calculates it from the number of times the fuel cap is opened (it has a sensor for this).
- x 1983
very true....it will depend if you do a lot of £20.00 "splash and dash" or always fill your tank. A good few times I have seen comments saying people get warnings and the addativeis at 40% (ish).Hell Razor5543 wrote:IIRC the computer does not 'know' how much additive there is (no level sensor), it merely calculates it from the number of times the fuel cap is opened (it has a sensor for this).
You will need a Lexia to "Re-set" the system after filling.... normally Indi garages do not have one.
The sensor is on the filler tube and the cap has magnets normally.
Dcourt
Cheers guys! I had a look this morning and there is still some fluid in there so I think it will be all good till Thursday
Cheers for your help
Dcourt
Had the fluid topped up and reset and the error message is still coming up! Any clue what this would be?
- x 1983
Hi....ummm
Was the work done at a Pug/Cit dealer ?
(if not) Did they Use the correct PSA software ?
Dcourt
No it wasn't done at a pug/cit dealer and I'm not sure what software they used
- x 3294
That is probably the reason the error has not cleared. PSA cars use their own proprietary software in the cars. As a result, normal generic car readers cannot 'see' PSA cars. You need to use a Lexia clone (which CAN handle PSA cars) to reset the additive counter.
