spinning TRE balljoint.
- chinkostu
- My Cars: N Xantia 1.9TD SX
03 Fiesta 1.4 Zetec - x 30
How in the blazes do you tighten up the nut on the track rod end? I've had it spinning the balljoint for fun, tried all manner of pry bars, cant get a clamp over the assembly, the nuts just up to the nylock
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
- My Cars: Renault 14...now skyward
Renault 19.. skyward also..
'03 Xsara 1.8 Picasso in silver met his maker
'06 Desire, again in silver also gonn to metal heaven
Re: spinning TRE balljoint.
any chance of getting a G clamp? with maybe a ball bearing at the nut end? or something on it to squeeze the taper into place, unless its the wrong taper angle........
oops 100 lines...........I MUST read the previous post properly...........
no clamp room...
Bob
no clamp room...
Bob
- (Donor 2021)
- My Cars: 2010 C5 X7 2.0 hdi 160 exc auto
MG TF 135
Boxer II 2.2 camper conversion
BMW R1200RT
BMW K1300 R
Honda V F R 800 5thG / MT500 Armstrong - x 39
no torx in the end of the threaded section? some have them and I think some don't..
try removing the nyloc (if possible) and doing up with a non nyloc until tight, and then nyloc?
I have , as a desperate measure, had some luck gently hitting the top of the TRE and tightening at the same time ...
John
John
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1289
- Contact:
Plain nut, a nice loose old one, then the lock nut.
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- My Cars: MK2 '17 C4GP 1.6 BlueHDi 120
'13 3008 1.6 HDi GripControl - x 994
I just squeeze them with a pair of water pump pliers - but pulling up the taper with a plain nut first can do it.
- chinkostu
If you use a plain nut first do you then double nut it or remove and then fit the nylock?
Hopefully get it sorted in the light, the 206 ones had the nut on top so were a doddle!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
- (Donor 2021)
MG TF 135
BMW R1200RT
BMW K1300 R
I would try and do it up and remove it, if that fails do it up and back it up with mr nylock
- My Cars: Currently:
C5 X7 VTR + Satnav Hdi estate Silver
C5 X7 VTR + Hdi Estate 2008 Red
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1204
I use about a 4' crow bar, press down on the joint/rod as hard as you can, it will usually go.
- chinkostu
Used my pry bar and got it nice and snug, then noticed i've slightly bent the inner rod :-/ its only a small curve though. Better than no steering!!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
- Stickyfinger
AX, little Daffodil
- Contact:
eeeee lad, they be strong ooup norff
brute force, without finesse!!
methinks
Bob
methinks
Bob
- darbuck
- Donor 2023
- My Cars: 2008 Citroen C5 X7 Tourer VTR+ (138 BHP)
2007 Nissan Primera P12 1.6 T-Spec (110BHP)
2003 Citroen C5 Estate level 2 (110 BHP) 2.0 HDI
2001 Nissan Maxima QX 2.0 V6 - x 141
two options one is a good slap of a hammer should hold in place or you could use an impact driver.
Darren
- chinkostu
When you've been at it a bit trying the less violent methods the red mist descendsStickyfinger wrote:eeeee lad, they be strong ooup norff
And i snapped the bloody abs post yesterday too, nipped it up and it didnt seem snug so gave it a small turn and snapped it clean. Bastard.
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
- Stickyfinger
AX, little Daffodil
- Contact:
what a boooger
