Two Xantia X1 photos and questions.
Saraphee
x 11
Unread post by Saraphee »
I believe the first photo is a tie-rod connector - is that so and where can a get them Please?*Image
The second is a hole in the rear n/s wheel arch - what should be in there and where can I get one*
If you can help with a supplier please bear in mind I need a website and a business prepared to post internationally!
Rex
x 1470
Re: Two Xantia X1 photos and questions.
Unread post by xantia_v6 »
For the dog bone, try http://www.ebay.com/itm/Genuine-Rear-He ... 1167722566
The rectangular hole is I think always open, nothing missing there.
superloopy
x 19
Unread post by superloopy »
Surely not [emoji45]
Hasnt this just been discussed somewhere (Sticky?). Or am i mixing this cover up with anothet topic.
Sent from my LG-D855 using Tapatalk
Mike
x 1997
Unread post by Stickyfinger »
Which ?
And a member (me?) would be happy to forward ship if you have a problem.....
superloopy
x 19
Thats the one [emoji1]
Mike
Saraphee
x 11
Thanks again to all.
I've now ordered a couple of the height corrector rods from eBay.
However they show nothing for a Rear Entrance Post Plug (as so described on the parts list - slightly unfortunate choice of description I feel)
So I'll beaver away on google and see what I can come up with!
Alasdair - thank you for that kind thought - something you can be sure I'll bear in what little mind I've got left.
x 1470
The hole you have shown in your photo is not the rear entrance post (which is an oval hole, not square), I think the hole you have shown is at the top of the wheel arch and has no plug.
Saraphee
x 11
The hole is certainly at the top of the wheel arch and is only on the nearside.
Am I correct in saying that the REPP is on both sides?
x 1997
The REAR END plug :) (I am such a child) is obtained only from a main dealer, I have not seen them on ebay. The sill can/could also be sealed with a mastic barrier.
I do not think it is that which you are after however........
