Citroen C5 trailing arm woes.
Hi,
So my C5 estate has had a horrible squeak and through a 3rd party warranty it ended up having new discs pads and calliper to fix the squeak. All this didn't work and the squeak came back, finally the warranty company authorised the radius bearing done (£208.89) on the 16th December, they showed me the old bearing and basically just a shell of what it was so it was defective. Since then the car has ran like a dream until yesterday, the squeak came back slightly, and is now getting worse back to how it originally was.
Any ideas of what's either caused the bearing to go again in less than 900 miles/could it have been installed wrong?
Cheers.
Mike.
Cheers.
Mike.
Current vehicle
2010 peugeot 3008 1.6 HDi exclusive
2007 Citroen C5 20.HDi estate exclusive
Past French cars
2000 Xantia HDi 90 Forte
2002 C5 HDi 110 LX
2002 Renault laguna 1.8 16v
2008 Renault laguna estate 1.5dci
Past French cars
2002 C5 HDi 110 LX
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1289
- Contact:
Re: Citroen C5 trailing arm woes.
Simple answer, yes it can be installed incorrectly or with the incorrect parts.....would that trash it in 900 mile, again yes it could.
Needs inspecting and claiming for the work to be re-done (IF that is the source of the squeak)
Same side ? were Both done ?
Activa, the Moose Rider
3x C5x7 Steering racks and counting
Understood, it is going in on Monday. But forewarned is forearmed so just wanted to know if it is tricky to install/easy to break.
Only drivers side was done. And yes it is the same side.
Current vehicle
Past French cars
2002 C5 HDi 110 LX
Past French cars
2002 C5 HDi 110 LX
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5710
This'll be an interesting one!
Hopefully not too interesting or it'll be getting traded in as I've fallen out with the car now. I knew I should have went for the grey 04 VTRs estate will 30k rather than the exclusive with 75k
Current vehicle
Past French cars
2002 C5 HDi 110 LX
Past French cars
2002 C5 HDi 110 LX
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
OK - fingers crossed - I just meant it will be interesting to see what the outcome is and where the liability lies if it is the same part causing the problem. Did your warranty company choose the garage for repair or did you? I guess as long as the garage is on their 'approved' garage list, then I suspect that your comeback is with the warranty company. Did the garage do the repair properly - if not how many times do you give them to get it right? Let's see anyway, keep us posted
PS I really loved my earlier Exclusive, I hope you can fall back in love with yours!
I chose the garage unfortunately, I also had to pay for the work, then claim it back. Which took three weeks. The garage I took it to is a reputable garage and as stated on their invoice, all work is gaurenteed. I think even when this issue is repaired I won't keep the car long.
So far in the last two months, I've had to
Change the battery
New front pads
New rear pads and discs
New rear drivers calliper
Passenger front calliper stuck on so had to be released
New rear trailing arm radius bearing
Had the tyre sensors turned off
Still faulty with the car
Rear boot window won't open
Drivers washer jet extends but won't spray
Wash bottle level season says fluid low even when full.
I think it's all just getting on top of me with this motor, none of my previous cars have ever given me much trouble.
Change the battery
New front pads
Current vehicle
Past French cars
2002 C5 HDi 110 LX
Past French cars
2002 C5 HDi 110 LX
- Stickyfinger
AX, little Daffodil
- Contact:
Once its fixed you know its fixed....as a tip, if they argue ask to photograph it as they strip it
FYI, this is the set-up
I wonder if they greased it ?
What is the general longevity of these bearings from time the car is new? Seems to be any time after 100k? Apart from heavy towing of course.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- Stickyfinger
AX, little Daffodil
- Contact:
I would say between 70-100K based on a "finger in the Air" feeling from this site ....they are a good design.
- My Cars: Two C5's...
Lots of CXs...
A couple of Xantia...
A C2...
Lots of Prelude's...
And a Sunny! - x 66
- Contact:
70-100k? Really? Is that all the expectation is?
That's a lot worse than I've ever expected out of a CX rear arm bearing (and they are far less idiot-proof to install and with worse quality seals)!
Iain
1x '85 CX GTi Turbo s1 (metallic blue)
2x '85 CX GTi Turbo s2 t1 (metallic silver & grey)
'88 CX GTi Turbo s2 T2 (metallic light blue)
CX DTR T2 Safari (silver)
2x '96 Xantia Activa (Black & metallic green)
Iain
- Stickyfinger
AX, little Daffodil
- Contact:
They often carry a lot....that said I have had ones over 120K and I bet others have more....personally I think there is a significant "time/age" factor as well where the will expire even with low miles.
I would regard it as a safe bet they will need to be done soon on all Mk1's if not replaced already and would budget accordingly. Not worse than struts/springs of metal cars really.
- daviemck2006
- My Cars: Far too many good ones to remember. Many BL, Vauxhall, Ford, Renault, Citroen, Peugeot, and now VAG
- x 488
My second c5 needed one at 115k. I sold the first c5 at 110k I think and it hadn't gone.
Skoda Karoq 1.6tdi 2018
Citroen relay camper 2012
In the family
Seat Leon 1.5tsi tourer 2019 daughter 1
C1 vtr+ 2010 daughter 2
In the family
- chinkostu
- My Cars: N Xantia 1.9TD SX
03 Fiesta 1.4 Zetec - x 30
Its more common than you think, rear beams on Saxo/106/zx/306 etc can be dead in as little as 50k if unlucky, mine had a recon beam in 2007 i think, i aquired it in 2010 and drove it to 170kish with no problems (had 120 when i bought it, probably 100k on original beam) so it seems the recon ones are as reliable.
Currently the Xantia had 71k and i'm currently thinking of getting the bits and doing the bearings in the summer as a precaution really as if they're left leaning the arms are unrepairable.
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
- My Cars: Currently:
C5 X7 VTR + Satnav Hdi estate Silver
C5 X7 VTR + Hdi Estate 2008 Red
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1204
I changed mine at about 190k but don't know if they had been changed before. Failure is due to lack of grease, if water gets in the bearing rusts away and disintegrates, I always fill the tube between the bearings up with grease, stands a sporting chance of keeping the water out and the bearings lubricated.
