Fitting a virgin BSI to a C5 SORTED
- My Cars: C5 V6 Mk1 assainated by wife
Renault Kangoo 1.6 auto, tarted up and remapped
Still missing the Xantia V6
Not missing the AX - Contact:
I have just had my BSI repaired and virginised after it threw one wobbly too many. I now have the task of fitting it back and matching it back to the engine and alarm ECU's. As this is a one shot only procedure do any of the erudite membership have words of advice on how not to cock it up? I have a four digit code which I obtained from Citroen and a Lexia, what next?
Lexia ponce
Lexia ponce
OnlineGiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5721
Re: Fitting a virgin BSI to a C5
Stempy - surely that's GOT to be worth an hour of anyone's money at the main stealers??!
Apart from not wanting to balls it up - won't the BSI need to have the right software downloaded too?
That's what I'm trying to find out. From what I can gather you have to enter the relevant code into the blank eprom then if all is well programming can be done manually with the Lexia by selecting whichever options came with the vehicle, but if there's more to it then it might well be a dealer job.
Lexia ponce
Lexia ponce
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
I would - for peace of mind - at least if they muck it up they can get all the data from their PSA main database in France that holds all the car BSI info. Also, sometimes not all the functions get programmed in first time with the Lexia clones and in some cases it has been known to suddenly loose a function that was there whilst programming in something else (this has happened to me - I cleared an unrelated fault and a week later found I lost the Driver Comfort function, so had to go back in and re-programme that in). Although the Lexia is a great piece of kit, for something like the BSI programming, personally speaking I would want to ensure the BSI was properly and fully programmed with the latest software update for your car that Citroen will have. Good Luck
Make sure you type in the confidential code 100% correct, you only get one shot at that. If you type it wrong you will need to send the BSI away to be virginised again. If your code contains the number zero don't confuse it with the letter O. Lexia now warns you that codes never contain the letters O or I. That's the only bit that's one shot, all the other options & equipment configuration can be changed as many times as you want.
Ideally you should have made a print out's of the original BSI configuration before removing it so it can be re entered the same, its fairly straightforward to configure it by 'eye'.
What did they actually do to the BSI ? is the latest software version been loaded ?
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
That's why I suggested using the dealer - as they will know the right software and any later update for that particular BSI, Model and RPO.
It can always have the software updated at a later date after the BSI has been initialised.
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
They should do this at the same time, as part of the coding and cost hence my suggestion. This is what happened when I had a diagnostic - led to a BSi software update to cure some niggles and was inclusive.
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3007
Not if a mistake has been made, and it has been bricked. I would not take the chance. If the dealer breaks it, then that is their problem, and (assuming no external fault) they have to then resolve it properly.wheeler wrote:It can always have the software updated at a later date after the BSI has been initialised.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
My point exactly - but on a lighter note, I just have visions of sitting there with the Lexia thinking 'should I push the button or shouldn't I' for an hour and then saying 'bu**er it, off to the dealer'! Not sure how much you paid to have it 'virginised', but if it does go toes up, then it's that cost again and the dealer cost on top of that to do it right - but your choice.
Being an engineer of the electronic persuasion it is extremely tempting to have a go. I have scoured the internet for information regarding this and there are folk out there who have successfully fitted a virginised BSI with their cloned lexias and instruction on how to do so. I have the key code supplied by a Cit dealer from my VIN no. so unless this is wrong there shouldn't be a problem as it seems like a fairly straight forward process.
I can imagine a Citroen dealer taking no responsibilty for bricking a BSI virginised by a third party company. Genuine replacement BSI's are no longer available from Citroen, and even if they were I'm sure they would cost substantially more than the car is worth being a 2002 model. It cost me £160 to have the BSI repaired and virginised which included replacing some of the components apparently. The guarantee is for 15 years and they claim it is improved from the original spec.
As far as software versions are concerned, it appears to me that all Citroen hold on file are configuration settings for the particular vehicle depending on what equipment was fitted at the factory. Firmware is another matter. I have a second spare BSI from another V6 with a later firmware version according to the sticker. Whether this is permanently embedded or not I don't know, but whatever the case as long as it works as it did when it left the factory I care not which software/firmware version it is as I can't see it making any difference to a car of this age.
So, the upshot is I've decided to give it a go myself and have set aside next Tuesday to do the deed. If all goes well I will report back, if not you'll find me on the Nissan forum......
Lexia ponce
Lexia ponce
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Copious amounts of coffee for the procedure, with copious amounts of brew on standby!
- My Cars: Two C5's...
Lots of CXs...
A couple of Xantia...
A C2...
Lots of Prelude's...
And a Sunny! - x 66
- Contact:
Yeah, just do it imo.
As others have said, all the config settings can be changed at any time.
Get a second opinion on the code typed in on the screen before pressing go?
I'm curious though, not having seen this before myself... Are you sure though that the code your bsi has been set to, will be the same as the code from the Citroen dealer? Is it possible it could have been set to a different code? (or does the bsi pick the code ip from somewhere else on the car itself).
Also what was the reason you had the bsi virginised in the first place?
Iain
1x '85 CX GTi Turbo s1 (metallic blue)
2x '85 CX GTi Turbo s2 t1 (metallic silver & grey)
'88 CX GTi Turbo s2 T2 (metallic light blue)
CX DTR T2 Safari (silver)
2x '96 Xantia Activa (Black & metallic green)
Iain
When fitting a new BSI or ecu the codes have to match and one interrogates the other for confirmation, that is why the units can't be coded unless fitted to the vehicle. The code is referenced against the vin number on the Citroen database so I would hope the dealer has supplied the correct information.
Lexia ponce
Lexia ponce
Oh, and the reason for having it virginised is because it was corrupt beyond redemption by any other method.
Lexia ponce
Lexia ponce
