- x 2000
Re: I am an Activa owner...a V6 and I am an addict
One day I may get to ride in a car with 17inch wheels, I would like to know how an Activa rides on them.
lexi
- x 134
One of the things that made the Vel Satis handle ( Along with ESP) was 245/45/18 rubber.
For a 1.8 ton car that thing was pretty impressive. Rough ride at rear through the town ruts mind.
Standard Xantia V6 was more agile though.
On a lighter note, the base C5 Donk is about as nimble as a B52 Bomber
great old thing!
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- x 8378
About the same as 15" wheels I'd imagine Alasdair, that's forwards, backwards, round corners and in some comfort...Stickyfinger wrote:One day I may get to ride in a car with 17inch wheels, I would like to know how an Activa rides on them.
- x 2000
You forgot the occasional sideways movement .............paRRP !
Quick general question from a dummy.....?
How much distortion do you get to the tread area (bulge) with over inflation, how much effect would say 10psi have in proportion to the reduction in flexibility ?
- x 2000
Did you ever check your throttle body Jim :0CitroJim wrote:I'll have to check one of mine but almost sure they should be a tight fit when closed.. As you say Stu, the ICU does all idle regulation duties and that bypasses the butterfly entirely.
In fact, when setting up the Lexia must see the butterfly properly closed...
- x 8378
No, but now you've reminded me...Stickyfinger wrote: Did you ever check your throttle body Jim :0
- x 2000
- x 3306
How many of the Hot Hatches will have centreless rims? That must have some 'bling' value!CitroJim wrote:Stickyfinger wrote: That and endless "it needs big rims" mate init
- x 8378
If not then start a new trendHell Razor5543 wrote:How many of the Hot Hatches will have centreless rims? That must have some 'bling' value!CitroJim wrote:Stickyfinger wrote: That and endless "it needs big rims" mate init
holmedog
- x 5
Yes it's definitely a trend setter but a costly one every time you need them balanced.
Sent from my GT-I8200N using Tapatalk
Gun Metal Grey Activa turbo,R.I.P. Gone to scrap yard in the sky and jims garage
Blue Activa from dr.madvibe
Silver Activa lost soul
wurlycorner
- x 271
Anyone tried Renault dealers for parts? I would presume they have their own parts network, entirely independent of PSA - and if they operate the same principles as Nissan, then there would be very good hope! (I can still get parts for my '86 SunnyCitroJim wrote: It's getting slightly worrying just how much now is going NFP for the V6.
Only just catching up on this thread.
Sticky, you are mad - that is work well beyond reason
I would expect that throttle butterfly to be completely normal. They are not going to be an absolutely airtight seal and the injection ECU sees the position based on the TPS, which is just driven by the spindle of the butterfly, nothing to do with pressure difference across the butterfly itself (he says, actually knowing nothing about the PRV engine and just assuming it's the same as all other cars!
Iain
CX DTR T2 Safari (silver)
Iain
wurlycorner
- x 271
Only just catching up on this thread.wurlycorner wrote:Anyone tried Renault dealers for parts? I would presume they have their own parts network, entirely independent of PSA - and if they operate the same principles as Nissan, then there would be very good hope! (I can still get parts for my '86 SunnyCitroJim wrote: It's getting slightly worrying just how much now is going NFP for the V6.)
Iain
Iain
wurlycorner
- x 271
Stupid idiotic double post
Iain
Iain
- x 2000
- x 8378
Oh yes, forgot to tell you, "Stupid idiotic double post" is now a term of serious abuse...Stickyfinger wrote:pardon ?
